Is this an EGA card?
First post, by Baoran
When I first saw the picture, my first thought that must be an EGA card, but later I started to doubt myself. I don't even know if you can recognize if something is an EGA card just based on the connectors and dip switches at the back of the computer.
The attachment card.jpg is no longer available
It has the dip switches and 9 pin connector. I think that is why I thought it might an EGA.
Reply 1 of 7, by Jo22
These two RCA connectors were typical for EGA cards.
I don't know what these were useful, though. Perhaps they weren't even functional ?
All in all, I *think* it is EGA, too (CGA only had up to one RCA, while Hercules often had one parallel port).
But I'm not 100% sure.. The 9pin connector was also used on early VGA cards, I believe.
https://allpinouts.org/pinouts/connectors/com … ideo/vga-9-pin/
Reply 2 of 7, by Baoran
Those RCA might be for a monochrome monitor?
Reply 3 of 7, by keenerb
that's almost certainly an EGA card...
Reply 4 of 7, by Baoran
Thanks. I bought the whole computer cheap and might get it late next week. I look forward to opening it for the first time and finding out what is inside.
Reply 5 of 7, by keenerb
You should be able to use a CGA monitor with an EGA card; all the 320x200 16-color modes will work but you won't be able to use the high-res ones.
Reply 6 of 7, by derSammler
