First post, by awgamer
Could someone update the database stats? I've just checked and added comments to several of the pre-0.74 broken game entries and another two were tested years ago that were never updated.
Tinker Tales 1984 0.63 broken not at moby Hangs with an Illegal CPU Call 7 error(checked /w 0.63, at running from prompt)
works with 0.74
Chuck Yeager ADF 1987 0.61 broken Dosbox freezes on a black screen adf start
works with 0.74
Manhattan Dealers 1988 0.65 broken Operation: Cleanstreets on moby Crash when starting
works with 0.74
Dragon Spirit 1990 0.63 broken I try running the EXE/Batch file and nothing happens.
broken with 0.74, playable with svn, glitchy graphics, gets stuck with high score list if pressed the wrong key
Inherit of the Earth (HD) 1991 0.60 broken installer tends to mess up on DOSbox. runs by extracting arjs manaully
works with 0.74 1994, not 1991
Winzer 1991 0.63 broken CGA, Hercules and EGA black screen vga & sound works,
works with 0.74, hgc, ega, vga, was no cga option, moby shows the same
Ancient Art of War in the Skies 1992 0.70 broken runnable now 0.74 entry from 2011, not updated in compatibility db..
works with 0.74
U.S.S John Young 1992 0.63 broken battle stations on moby CPU GRP5 : Illegal Call 7(checked /w 0.63, after selecting menu start)
works with 0.74
Worlds Of Legend: Son Of The Empire 1993 0.70 broken selecting the soundblaster as the soundcard sound isn't correct.
works with 0.74 sounds ok to me and 0.70 sounds the same.
Town with no Name 1993 0.73 broken run the executable throws back to the commandline, without any message or error.
broken with 0.74, works with svn
Trial By Magic 1995 0.63 broken no error feedback given
works with 0.74 changed game ,bat, was set to cd to root instead of sub dir, set sb16 wants dma 5 or silent and freeze.
Football Glory 1995 0.61 broken After launch, the screen remains black...
works with 0.74
Cadillacs & Dinosaurs 1995 0.63 broken the second cataclysm start the game it says "system timer 2 error".
works with 0.74 normal core
Ganja Farmer 1995 0.72 broken *MUST* use dynamic core /w 10k+ cycles, else run but very slow and crash often
works with 0.74
U. S. Marine Fighters 1996 0.58 broken Protected mode
works with 0.74
Project Paradise 1997 0.72 broken needs config.sys /w files=100, runs well, compat list needs updating
works with 0.74
Tie Break Tennis 98 1998 0.70 broken Game won't run - it just crashes.
works with 0.74
Reply 1 of 1, by awgamer
I didn't enter the subject field and it silently rejected them, didn't come up I guessed comments were being held back for review, added the comments again this time they took.
