Little Big Adventure 2 (Steam version)
Reply 21 of 23, by Dagar
Here are the 3 files that compose the CD on the GOG release:
LBA2.DAT (cue file) - 134 bytes
LBA2.GOG (main CD) - 664 mb
LBA2.OGG - 3.77 mb
Reply 22 of 23, by KainXVIII
collector wrote:
Then it should be mounting a cue sheet instead of the image. Is LBA2.DAT is a cue sheet and LBA2.DOT the image?
Yes, its disguised cue/bin files, i think.
Reply 23 of 23, by rcblanke
Jorpho wrote:
... According to the DOSBox readme, the only valid types for "-t" are "floppy", "cdrom", and "hdd", so whoever made that .conf file definitely messed up more than once.
I think that before '-t cdrom' came into play, '-t iso' was used in DOSBox to mount cdrom images. This is still supported in current DOSBox versions, AFAIK.
