First post, by BLockOUT
Hello
A seller sent me this picture of the CPU we wants to sell me
Is the dell thing a voltage regulator?
The dx4 is a 3volt cpu, with that thing it gets transformed into 5volt? and by doing that the dx4 can be used on older motherboards that don´t support voltage setup jumpers in the board?
Reply 2 of 9, by Deksor
Just a quick search on the name of the small "transistor thing" at the top on goolgle leads to these results https://www.google.fr/search?q=LT1587&ie=utf- … K3QCw&gws_rd=cr
So this component is a VRM that regulates the current to ~3V 7A.
I don't see why it would be there if that whole thing wasn't a voltage adapter ^^
Reply 3 of 9, by BLockOUT
before trying this out, i want to show you something weird
this is the back side of the module, as you can see the pins that are grey are pins that were cut/no contact pins
does anyone have a 5v to 3v converter? is that normal?
there are many pins that were cut!
Reply 4 of 9, by Anonymous Coward
It looks like all the missing pins are Vcc. Maybe the CPU is getting Vcc from the pins normally supplied to the Pentium Overdrive (the extra outer row on the socket not used by regular 486 CPUs). I'm not sure why they did this. Maybe it was to key the CPU to prevent improper insertion?
Reply 5 of 9, by feipoa
Lookup the pinouts for the 486DX4 to see what those pins are for. They may be non-connect (NC). It is pretty neat to see a Dell branded VRM module. It was probably intended for a Dell motherboard, but may work in others as well.
LT1587 is very common for use as a CPU voltage regulator. It has a low dropout voltage. There are few other common ones, off the top of my head, the 1085. For regulators which take 5 V down to only 4 V, they often use an ultra-low dropout regulator, especially for higher amp drawing CPUs.
Reply 6 of 9, by Ampera
It's a VRM and I wouldn't worry about the missing pins. It's not as if they are ripped out. It's quite obvious it's not needed, and that it will fit into any Socket 3.
Reply 7 of 9, by feipoa
This is the first 486 VRM interposer module I've seen which contains 4 rows of pins. The only other is the POD. Anyone remember what the 4th row of pins is for?
Reply 8 of 9, by Anonymous Coward
Extra grounds and power. No signalling whatsoever. Other's have already demonstrated that a POD can work in a 168pin socket if you can get enough clearance.
Did you see the guy that stuck a POD83 in his XT using the Transcomputer 486hpi and Inboard?
Reply 9 of 9, by feipoa
Nope. Link?
