X2GU : New GM bank for DreamBlaster X2
Reply 20 of 127, by dreamblaster
okay, here's doom then :
https://soundcloud.com/dreamblaster/sets/x2-d … m1-on-different
comparing :
Doom E1M1 on GUD 0.6 bank (with doomtastic2 preset)
Doom E1M1 on default Dream bank (with doomtastic2 preset)
Doom E1M1 on GUD 0.6 bank (with audit preset)
Which one do you like best ?
If we have new revision of the GUD bank, I will add it to the same playlist.
Will try to find time to do more recordings next weekend.
Feel free to download the GUD 0.6 bank and test any games you like.
feedback is welcome.
Thanks for your support !
Reply 21 of 127, by Falcosoft
Hi Serge,
Last week I promised you in email that I would test this new GM bank. Since I have found this dedicated topic I post my results here.
Generally this new GM soundfont is very good. I have only found 2 minor issues:
1. Program 79 Ocarina sounds a little off-tune.
2. Program 97 Soundtrack uses too much pitch slide effect that can be disturbing in songs that do not use Soundtrack as an effect but as an instrument.
Ps. None of these problems can be heard with the original GeneralUser GS soundfont.
I have made a video about these problems (unfortunately in the video I used Reality_GMGS_falcomod and not GeneralUser GS as a reference).
https://youtu.be/Kqfc7eQ3pZU
Website, Youtube
VST Midi Driver Midi Mapper
Reply 22 of 127, by clueless1
@dreamblaster-thanks for posting these!
Of those three, my personal favorite is X2 : DOOM1 E1M1 : Audit preset : GUD 0.6, followed closely by Doom E1M1 on GUD 0.6 bank (with doomtastic2 preset). They are very close to each other, but I prefer Audit preset because it has a little more bass and warmth. Default Dream Bank is a distant 3rd. To my ear, the guitars sound least real with the default dream bank.
Reply 23 of 127, by dreamblaster
@Falcosoft : thanks, excellent, will try to get this fixed.
@clueless1: okay, thanks, I uploaded some more soom recordings to complete your comparison options :
Doom E1M1 on default Dream bank (with audit preset)
Doom E1M1 on default Dream bank (with audit2 preset)
Doom E1M1 on GUD 0.6 bank (with audit2 preset)
audit2 has a little more effect pass through than audit. (both can be downloaded from http://serdaco.com/downloads/X2/X2_SoundbankPack/GM/GUD/
Reply 24 of 127, by Whiskey
I'm having a little trouble with this beta soundbank. I've flashed my X2 before with no issue but the 0.6 sound bank beta seems to produce the same off instrument rendition of the Monkey Island opening that I was getting before with the default GMBK5X128 Soundbank.
Link to what I'm hearing. https://soundcloud.com/whiskeyjuliet/x2-gud-b … g-and-scene-one
I've defiantly flashed the X2 correctly (more than once) and used the Audit Preset too. As you can hear it sounds nothing like the 0.5 recording @Dreamblaster provided. Any thoughts? Cheers W.
EDIT: Somthing to note, when using Zoltan Bacsko's Midi Player 4.6 and playing the Midi awmonkey.mid (attached) I get a accurate rendition of the theme. But the Extracted MT-32 Midi MI_1.MID (attached) gives the same incorrect instruments I get in game. I am launching the game currently from DOSBOX with the X2 setup as the MIDI device over usb. (But am also getting same results on DOS with an ISA ESS Audiodrive and the X2.) This makes me wonder if its a problem with MT32/Roland midi instrument numbers and the X2?
I stream retro games every wednesday here & I dump the recordings here
Reply 25 of 127, by PhilsComputerLab
Monkey Island doesn't support General MIDI, but the Roland MT-32. It's likely that the MIDI file used was a conversion, which can lead to confusion. I try to avoid using such MIDI files, and there are many of them, as it can make you believe the game will sound just like that on a real machine when it won't.
Unless there is a way to re-configure the X2 to use the default MT-32 instrument layout, it won't sound correct in that game.
YouTube, Facebook, Website
Reply 26 of 127, by dreamblaster
Yes that's right, as the soundcloud description says: https://soundcloud.com/dreamblaster/x2_monkeyisland1_gud05
this is GM midi file : migm1.mid (Monkey Island 1 theme GM version).
I had recorded this because someone requested, but indeed monkey island 1 is not a General MIDI game,
and theres no simple patch as far as i know, but maybe try the Monkey Island Ultimate Talkie Edition ? http://gratissaugen.de/ultimatetalkies/monkey1.html
This supports general midi 😀 I didnt try yet, curious to hear your result !
Reply 27 of 127, by Whiskey
Thanks Phil for the quick reply. I was just editing my post and surmised as much. I wonder if a alternative bank with the Roland Instrument layout could be made as the new bank does sound very nice. Not sure on the complexity of this but I think it's just a case of reordering the patches and the banks to the Roland spec?
http://www.voidaudio.net/gsinstrument.html
I'm now starting to understand the difference between GS and GM. I never had a dedicated midi device when I was younger only a Sound Blaster 16.
EDIT: @Dreamblaster Ah ha, I didn't know there was a General Midi supporting version of MI1 I'll have to give it a try and report back. I feel like a right plum for not realising the difference between GS and GM.
Reply 28 of 127, by dreamblaster
Okay also this :
the X2 dream bank is a GS bank.
The GUD 0.6 bank is a GM bank -- only GM instruments.
But that's not a big problem I guess, most games only use GM.
Reply 29 of 127, by PhilsComputerLab
That is likely doable but there are some challenges:
- The default MT-32 instrument layout will work with a few games. Games basically that just stick with the default layout for the entire game. Most MT-32 games however "program" the MT-32 in a way that only the MT-32 can understand
- The other issue is that then everyone will think the X2 is fully MT-32 compatible and will have a negative experience when they find out it's not
Reply 30 of 127, by Falcosoft
I have a feeling based on the above that you think MT-32 is a GS device and this is the problem here. No, GS is another Roland midi system based on GM. But MT-32 is neither of them. MT-32 precedes both GS and GM.
Website, Youtube
Reply 31 of 127, by Whiskey
@Falcosoft My error is rather clear now. I'd assumed each was built on its successor mt32 > gs > gm . But it's obvious now that I couldn't have been more wrong. Thanks for the info and the great Midi player.
Reply 32 of 127, by dreamblaster
New recordings : X2 playing tie fighter intro with GUD 0.6 bank and Dream Bank (using audit2 preset)
https://soundcloud.com/dreamblaster/sets/x2-t … intro-different
And here are the X2 DOOM E1M1 recordings, different presets all added to one playlist :
Reply 33 of 127, by Whiskey
Here is as suggested a recording of the General Midi version of The Secret of Monkey Island opening from the Ultimate Talkie Edition.
It sounds pretty good, really nice volume balance and instruments. Thanks for all the comments before about where I was going wrong.
https://soundcloud.com/whiskeyjuliet/dreambla … -talkie-edition
EDIT: Additional! Sam and Max Hit the Road
https://soundcloud.com/whiskeyjuliet/sam-max- … credit-sequence
Reply 34 of 127, by keropi
very nice
with more feedback and error-pointing the bank will become really great 😁
Reply 35 of 127, by Doppler
Could someone share renders of Warcraft 2 soundtrack? 😜 Would do it myself but dont have the time ;(
Reply 36 of 127, by Falcosoft
Here you are, 4 songs of Warcraft 2:
https://youtu.be/US6E1hdKW10
Intro: 0:00
Menu: 2:52
Human1: 3:33
Orc1: 6:03
Ps: The piccolo at the end of Orc1gm (channel 9) sounds a tiny little bit off-tune.
Website, Youtube
Reply 37 of 127, by James-F
I don't hear the Crash Cymbal on Doom E1M1 that should start at around 00:10 with the GUD bank, but I do hear it in FSMP with the GeneralUser SF2 or SC-55.
Can someone confirm?
Reply 38 of 127, by Whiskey
Agreed. It is there on all of the Dream Bank recordings, but none of the GUD 0.6 recordings. Regardless of the level presets used.
Cymbals start on the snare beat at 9 seconds in.
Reply 39 of 127, by Falcosoft
I can also confirm it.
@Serge:
I have already written an email to you about a problem with the DB X2 Piano soundfont. The problem is very similar to this case.
"I would like to report a problem relating the beta Piano soundfont. It seems that the velocity to volume curve is not right. At velocity level 50 - 60 the piano's sound is almost inaudible. The volume of the notes should be this low at velocity level 0 - 10 not at 50 - 60. I have attached a test file where some notes are inaudible because of this.
If you use the latest Midi Player (4.6) there is a new midi event debugger (Ctrl + D) that can be used to test this bug. If you modify the notes velocity value that are 50 - 60 to e.g. 80, the notes that are inaudible so far suddenly appears."
In Doom E1M1's case the Crash Cymbal (A4(57) on track 4/channel 10) uses velocity values as low as 23. These notes are completely inaudible. The other A4(57) notes use velocity values between 56-64. These are also very quiet.
Website, Youtube
