First post, by psychz
- Member
Got myself a Diamond Monster 3D 4mb PCI with a knocked capacitor which got replaced immediately, and decided to use it with my P100 build for DOS Glide gaming. With Tomb Raider, it appears to work, however I get dark vertical bars. Happens every time after the 3dfx switches outputs, starting when it shows the logo, and goes normal again when switching back to the S3. Could it be dry caps or something else? Also, is there any way to test its memory? I had Screamer 2 crash on me twice and noticed some weird colored pixels, a behavior which Tomb Raider doesn't exhibit at all so far. All chip legs are straight, card looks okay as far as I can tell. I'm pretty sure I've seen similar behavior on a Cirrus Logic 542x VLB before, didn't know the cause back then either, suspected bad caps but not sure.
wrote:Its not like components found in trash after 20 years in rain dont still work flawlessly.
