First post, by videogamer555
I thought in 80x25 (80 character by 25 character) text mode, it was supposed to have a pixel resolution of 640x400 (and it appears to be so in DOS Box). However when running DOS in Oracle VirtualBox (when booting to a MSDOS 6.22 floppy disk image), and I measured the width and height of a screencap of the virtual machine's screen window, it appears to be 720x400. And if you look closely, the spacing between typed characters in VirtualBox is a bit wider than the spacing in DOSBox (though the size of the characters themselves is the same). Here's a picture that shows cropped sections of screenshots from each PC emulator (DOSBox and VirtualBox), showing the character spacing.
Which more closely resembles the behavior of real hardware?
Reply 2 of 5, by Jepael
VirtualBox is right.
This is also a known feature of DosBox. It may not matter much as there's not that many text mode games, let alone text mode games that this would present a horrible graphics issue.
Any way, if the screens are 640x400 or 720x400 pixels, then when they are viewed on a modern display with square pixels, they both have incorrect aspect ratio, as the image should be viewed on a 4:3 aspect ratio where the pixels are not squares.
Reply 3 of 5, by Scali
Is that still relevant though?
I have a 4k monitor, and 1:1 pixel mapping is the last thing I want from an emulator. Those old resolutions of 320x200 and 640x480 are REALLY small on my display, so I want to stretch them by a significant amount anyway. Might as well perform some aspect correction while I'm at it.
Reply 4 of 5, by leileilol
Sadly i've seen plenty of "real dos screenshots" on the internet taken through the cut-down dosbox textmode res...
Reply 5 of 5, by ripsaw8080
Rank DOSBox Author
DOSBox Author
You can use the machine=vgaonly setting in DOSBox if the 720x400 resolution of VGA textmode is important to you.
