First post, by bluejeans
Haven't dealt with internal speeds before, just bus speed. Board originally came with a dx33 set to 2x internal speed.
Reply 1 of 5, by elod
The internal multiplier is just that: internal. You have no influence over it. Except when it's meant to be changed by software. Not on the 486.
Reply 2 of 5, by sunaiac
Some dx4 are 2x compliant (2x50 is an official dx4-100 speed I would guess)
I don't know of any 2.5 compatible 486.
What is the exact model of your processor ? (sspec if intel would allow to check on cpu-world)
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 3 of 5, by PhilsComputerLab
Yes it depends on the CPU mode. I did this with an AMD DX4 100 back in the old days. Had switches put into the case to let me control the multiplier and FSB, which let me run the machine from 50 MHz to 120 MHz 😀
YouTube, Facebook, Website
Reply 4 of 5, by Ampera
I see no reason you shouldn't underclock your CPU. It's more of a question of can you. The short answer is if there is no jumper and there is no BIOS option, there is no way to do this.
Reply 5 of 5, by bluejeans
The attachment 20170506_121914.jpg is no longer available
