First post, by bluejeans
Still not familiar with this kind of bus ratio adjustment.
Reply 1 of 5, by Skyscraper
3/2 = 1.5x (and 3.5x)
2/1 = 2x
3/1 = 3x
5/2 = 2.5x
Reply 2 of 5, by bluejeans
Skyscraper wrote:
3/2 = 1.5x (and 3.5x) 2/1 = 2x 3/1 = 3x 5/2 = 2.5x […]
2/1 = 2x
3/1 = 3x
5/2 = 2.5x
So this board allows underclocking? For overclocking it has a huge heatsink on it, twice the size of the cpu and 4cm high, the 133 in it might just get to 166.
Reply 3 of 5, by meljor
Sure, you can set the 133 as low as 1,5x 50 or 75mhz.
Reply 4 of 5, by bluejeans
Is it true that pentiums are double the clock speed of a 486, e.g a pentium 100 being twice as fast as a 486-100?
Reply 5 of 5, by Sedrosken
In ideal circumstances, meaning that they're running Pentium-optimized code, yes, due to the fact that it would be keeping the dual pipelines filled. But we don't live in a perfect world and ideal circumstances are rarely in effect, so, running code meant for older x86 chips it wouldn't necessarily be twice as fast but it would still have a significant advantage.
Shoushi: Dimension 9200, QX6700, 8GB D2-800CL5, K2200, SB0730, 1TB SSD, XP/7
Kara: K7S5A Pro, NX1750, 512MB DDR-286CL2, Ti4200, AU8830, 64GB SD2IDE, 98SE (Kex)
Cragstone: Alaris Cougar, 486BL2-66, 16MB, GD5428, CT2800, 16GB SD2IDE, 95CNOIE
