First post, by GiSWiG
I have not found the answers I'm looking for so I figured this would be the place to ask seeing that I'm looking at using older hardware for older games, just under a new OS. I'd also mostly be playing using headphones (HyperX Cloud II)
I ordered a Sound Blaster X-Fi Titanium for an XP retro/GOG/Steam PC which still has EAX support and should provide EAX support for older games. But what about EAX support under Windows 10?
As far as I can see, the Sound Blaster Z does not support EAX? T of F?
Can the X-Fi series provide EAX under Windows 10?
Steamer/GOG-er: ASUS Crosshair IV Formula | AMD Phenom II X6 1100T 3.7GHz all cores | Mushkin 8GB DDR3 RAM 1333 w/ 6-6-6-18 1T | Dual AMD Radeon HD 6850s in CrossFireX | X-Fi Titanium | Dual-boot Windows XP and Vista
Reply 1 of 23, by GiSWiG
To add, I'm using a MSI GAMING M7 w/ Realtek ALC1150 on-board audio. I've never been impressed with the Nahimic audio software that seems to come with only MSI motherboards and laptops.
Reply 3 of 23, by Stretch
Yes, EAX will work on older games but you have to download Alchemy from Creative's web site.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Cubilux 7.1 USB
Reply 4 of 23, by GiSWiG
For X-fi, SB Z, or both?
Reply 5 of 23, by mrau
my understanding is that is OS related, not hardware
Reply 7 of 23, by GiSWiG
Cool. Get the X-fi now on the cheap, save up for the Z
Reply 8 of 23, by PhilsComputerLab
Yup, both support it 😀
There is also this Recon 3D, but it was a bit of a dud. It uses similar software to the Z. All these cards support ALchemy. There are a few USB sound cards, Play! or something. So yea, basically a lot of Creative cards will restore EAX through ALchemy.
YouTube, Facebook, Website
Reply 9 of 23, by awgamer
What does the sb z have over the x-fi?
Reply 10 of 23, by lagonauta
Probably better drivers for Windows 10, but overall the X-Fi is considered better (has hardware acceleration, EAX is more accurate (even though a CPU can make the same effects, Creative choose not to. Maybe to sell more X-Fis, who knows), has more outputs, and some PCI cards can even decode DTS/Dolby from SPDIF In)
Reply 11 of 23, by kode54
X-Fi also has the remarkable hardware resampler engine, which they make a Big Deal out of in some of their marketing materials. I'm thinking some sort of high quality adaptive sinc resampler with quality filtering stage. They suggested that the resampler made up over half of the processing capability of the card.
Reply 12 of 23, by GiSWiG
After watching your video on the SB Z and I know you've use X-fi in other builds, what do you think? For now, I got a good deal on the basic X-fi Titanium. Would you consider a high tier X-fi or SB Z for Win 10?
Reply 13 of 23, by PhilsComputerLab
The Z is a very good sound card, but it's not compatible with Windows XP I believe. So the X-Fi might be more flexible?
Both sound great, it's hard for me tell if one sounds better than the other...
Reply 14 of 23, by GiSWiG
Well, as much as I love the classics, I like the new stuff too and I use Windows 10 primarily but most of my Steam games are 'retro' so if I can run EAX in Windows 10, great! If an X-Fi for $20 can do that vs. getting a Z, then that's good too. I have a red and black theme going so the SB Z would look really nice. So I will have an XP PC that I can get another $20-ish dollar X-fi and then budget for the SB Z for later.
Reply 16 of 23, by SRQ
I have an SB-Z and yes, it does.
Reply 17 of 23, by GiSWiG
Thanks everyone. I'll stick with the X-fi for now then move up to probably the Zx
Reply 18 of 23, by lagonauta
For those interested, I made a small program in C# to be able to use OpenAL, EAX and any other effect from the X-Fi DSP on any other audio interface (HDMI, Realtek).
When I moved my computer to Windows 10 I also bought a Titanium HD as it has not only better audio but also better support for this version of Windows, but I missed the surround sound from my X-Fi Titaniym Fatality Pro.
I noticed that one can use ASIO to record any output of the X-Fi, even in Game Mode, so... "ASIO Rec and Play" was born 😀
This software will record the output of the X-Fi and route it to any other ASIO interface. I am using ASIO4ALL.
I am very sensitive to latency, but I felt none.
I released it on GitHub:
https://github.com/LAGonauta/ASIORecAndPlay/releases
Enjoy 😀
Reply 19 of 23, by Presbytier
So I actually just bought a X-Fi Titanium Fatal1ty brand new in the box off of eBay myself for my Windows 10 system. I was using a Sound Blaster Z, but that only emulates EAX 3,4,5 it does not do it in hardware. So I hooked up the X-Fi installed the drivers and it works great and I swear CMSS 3D sounds much more accurate then SBX does. I have one question though on the mixer tab there is an option to enable EAX what exactly does that do? Does it effect EAX effects in the game or only apply EAX effects on the Microphone?
EDIT: So after some testing in both Quake 4 and Doom 3 clicking the EAX on button in the mixer definitely changes the audio. In Quake 4 it actually seems to add more effects to some explosions but can sound tinny and in Doom 3 everything becomes a bit more echoy. I am not sure if I should leave it on or off because it does appear to actually effect the ingame effects, so any advice on the proper settings would be much appreciated.
"Never pay more than 20 dollars for a computer game" - Guybrush Threepwood
