First post, by ScoutPilot19
- Member
I have a working 6mhz AT 5170 with 640k RAM and 20 + 30 mb MFM HDD. Tried to use in it common ISA-16 IDE IO card and a ISA-16 SCSI card, working on "common" 1988-1990 AT 286's, but in the IBM 5170 they hang the system(... Can it be solved or maybe some special SCSI hard must be found ? I heard people use SCSI HDD's in XT class machines... Common ISA16 VGA and SB clone work in that 5170 welL..
