First post, by tanasen
Hello. Today I bought an old pc for 36 euros ($39). It has a Celeron 900 and a Geforce 2 MX400 64mb AGP on a QDI Advance 10B motherboard and 512mb SDRAM. Seems to work well, except for the cd-rom drive which I replaced. So I found the manual from this motherboard and it says it supports Coppermine Pentium 3 1000 and all later cpu's with 133Mhz bus. Will I be able to install a Tualatin pentium3 cpu on this motherboard also? Will I need to install another bios version to do that? Or the best cpu I can install on this m/b is the 1133 Coppermine? Thanks!
PC1😜 III-S 1.4GHz, GA-6VTXE, 512MB SDRAM, Albatron FX5900XTV 128MB, SB Live! 5.1
PC2😜 III 800MHz, MS-6178, 256MB SDRAM, 3DFX Voodoo3 2000 PCI, Creative CT4810
PC3😜 MMX 200MHz, SY-5EAS5, 128MB SDRAM, Diamond Monster 3D, Diamond Viper V330, ESS 1868F
Reply 1 of 8, by meljor
Maybe a modded cpu will work but otherwise no tualatin support on that board/chipset.
Reply 3 of 8, by tanasen
Well in US maybe you could find that a bit cheaper, but in greece I searched for about a month to find a perfectly working 1999-2000 spec pc with less than 50euros.
I also have another system with a coppermine 800. Will a 1000MHz SL52R Pentium3 be significantly faster than the celeron and the 800mhz pentium3? Is such an upgrade worthy? I found that chip for about 15 euros on ebay.
Reply 4 of 8, by melbar
Look at these benchmarks, there are a lot of CPU's inside ...
http://www.tomshardware.com/reviews/benchmark … rathon,590.html
Considering these values and that the test benchmarks were done with a Radeon 9700pro / GF4-Ti4600,
you can see these values (Q3 / 3Dmark2001 / UT2003, games in 1024x768), the values for the Celeron 900 are interpolated and shall be ~OK 😎 .
    16.58 KiB
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 5 of 8, by tanasen
Thanks a lot melbar!
Reply 6 of 8, by tanasen
So I bought the other day the P III 1000EB for 6 bucks from ebay. I'll update in a couple of weeks when I get it on my hands.
Reply 7 of 8, by PcBytes
I have a 10B as well and it supports Tualatin.
Reply 8 of 8, by tanasen
What cpu do you have on your 10B?
