Reply 921 of 5019, by kithylin
TheAbandonwareGuy wrote:
In short: No fucking way Way too much wattage with that dual GPU monster and that CPU. That's a pathetic amperage. My 500 Watt E […]
brassicGamer wrote:
Retrieved from a PC being chucked out, which apparently has never been used - the fans and the heatsink are clean as a whistle!
FSP400-60GHN. 17A and 15A on the 12V rails so not that impressive really, especially considering it's got 2x 6+2 PCI-e power connectors and 2x CPU connectors. I wonder if it could run a Phenom X6 with a 4850x2? Plus a silent Coolermaster S775 HSF. Not pictured: Core 2 Duo E8300 from the same PC.
In short:
No fucking way
Way too much wattage with that dual GPU monster and that CPU. That's a pathetic amperage. My 500 Watt EVGA has 50 amps on the
12v rails and it struggles with a lesser load (E8400, 9800GX2, 4 Hard drives, 2 disk drives). Also doesn't the 4850x2 need a 6+8 pin connection?
Just an FYI. The official specs for the HD 4850x2 says 250 watts power max, and the slowest Phenom II x6 is 95W, while the fastest one can be up to 125W. So you're looking at 345W minimum up to 375W max just for the cpu and gpu alone. And like abandonware guy said have to factor in case fans (likely 10-20 watts each) and hard drives and optical drives. You -might- could get by with a 500W unit, but that 400W you have there won't cut it. It would just trip OCP (over-current protection) and shut off the computer the second you tried to engage a game using both gpu cores. For a setup like that I'd strongly recommend a modern 80+ gold unit @ minimum 600 watts to be safe (you want it about +10% over your intended load) and would probably set it up with a 700-750 if it was me.
Reply 922 of 5019, by brassicGamer
In short:
No fucking way
Thanks for the advice, dudes, but I was mostly being sarcastic. 😀 I got myself a 750W PSU last month specifically for the Phenom Crossfire project - this PSU only caught my eye because it's now the 2nd best one I have thanks to its capabilities. It just amused me how it is actually 8+6 capable but clearly would never be able to handle that!
Reply 923 of 5019, by Aideka
In short:
No fucking way
Not that I disagree with the other things here, but how does a 500 watt PSU have 600 watt output from its 12v line?
Reply 924 of 5019, by kithylin
In short:
No fucking way
It doesn't and can't. And some inferior power supplies can't even deliver the power on their sticker either. Like for example I have a CoolMax 600-watt here. But it can't actually deliver more than 400 watts, and I'd never risk it in any of my important systems.. it's just for like powering a random hard drive or some fans or a spare water pump during rebuilding water systems, etc.
Reply 925 of 5019, by Brickpad
Picked this Dell Precision 330 up from my school (not the actual photo of the unit, but similar) as they were in the process of throwing it out. It was originally running Windows Server 2003, which I removed and installed Server 2000 in its place. While the power supply unit appears to be in good shape, I am considering purchasing an ATX to Dell adapter and replacing it with my Antec 500w just in case. I may also upgrade the RAM to 1GB, and swap out the Radeon Ultra with a 3d Labs Wildcat II 5000.
Specs:
Pentium 4 1.4GHz (Socket 423)
512MB RAMBUS (4x128MB)
CD-ROM or CD-RW?
1.44MB Floppy
100MB Zip Drive
3x 18.2GB Seagate Cheetah (LV SCSI)
ATI Radeon Ultra
Reply 926 of 5019, by chinny22
I'm not 100% sure but I think Dell had moved over to standard ATX by then. it was mostly P2/P3 era stuff that was affected
Reply 927 of 5019, by kithylin
I own a Pentium4 era dell optiplex system and one time pulled the ATX plug to stick it in a ATX tester and it would not come on. But plugged it back in the motherboard and it comes on fine. I think the wires in it's "ATX Plug" are different wiring than standard atx plugs. I don't know when they switched over but.. something to think about. I would suggest pulling the ATX plug on your dell system and holding it to a normal PC power supply and just verify all the correct wires are in the same place on both before sticking something in your dell if it was me.
Reply 928 of 5019, by Carlos S. M.
some early P4 Dells still used propietary PSUs like the Dimension 8100 and the Precision 330
Reply 929 of 5019, by TheAbandonwareGuy
Brickpad wrote:
Picked this Dell Precision 330 up from my school (not the actual photo of the unit, but similar) as they were in the process of […]
Specs:
CD-ROM or CD-RW?
1.44MB Floppy
100MB Zip Drive
ATI Radeon Ultra
ATI Radeon Ultra? Could you post pictures of the card? Ive never heard of this. I'm guessing some sort of Dell OEM Radeon DDR?
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 930 of 5019, by Carlos S. M.
Specs:
CD-ROM or CD-RW?
1.44MB Floppy
100MB Zip Drive
ATI Radeon Ultra
Acording to the Dell drivers download page, it seems all stock cards listed are:
Geforce 2 GTS
3D Labs Wildcat II 5110
Matrox G450
TNT2 Pro
ATI Radeon VE
ATI/S3/Diamond Fire GL2
Quadro2 Pro
There are also chances the card got replaced in the past
Reply 931 of 5019, by TheAbandonwareGuy
Carlos S. M. wrote:
Acording to the Dell drivers download page, it seems all stock cards listed are: Geforce 2 GTS 3D Labs Wildcat II 5110 Matrox G4 […]
Specs:
CD-ROM or CD-RW?
1.44MB Floppy
100MB Zip Drive
ATI Radeon Ultra
Geforce 2 GTS
Matrox G450
TNT2 Pro
ATI Radeon VE
Quadro2 Pro
That just makes me even more curious about what that card is?
Reply 932 of 5019, by appiah4
I believe there was a Rage Ultra which I think the poster may have mixed up with Radeon Ultra? However a Rage Ultra card in a P4 system? Unlikely..
Reply 933 of 5019, by Carlos S. M.
There are, ATI Rage 128 Pro Ultra, is a OEM version (although Sapphire also sold a Rage 128 Pro Ultra card as well) of the Rage 128 Pro as low end card in late P3 era and P4 era, it was found mainly in Dell DImension and Optiplex series
Specs:
Core clock: 130 mhz
Memory clock: 130 mhz
Memory bus width: 64 or 128 bit depending of the card
Dell models which probably featured the ATI Rage 128 Pro Ultra as i know:
Dell Optiplex GX150 (Optional card as alternative to the onboard video)
Dell Optiplex GX240 (probably standard videocard since it lacked onboard video)
Dell Optiplex GX400 (probably standard videocard since it lacked onboard video)
Dell Dimension 4200
Dell Dimension 4300
Dell Dimension 4400
Dell Dimension 4500
Dell Dimension 4550
Dell Dimension 8200
Reply 934 of 5019, by Brickpad
Yes, I mixed it up. It's been a long day. The card is in fact a Rage 128 Ultra, and I replaced what was a GeForce 2. The silkscreening on the underside of the card is placed in a spot that distorts the lettering, and I misread it as "Radeon" not "Rage 128" (trust me, it's scrambled by the through-holes that at first glance it looks like RADEON). The fan was locked up pretty tight, so I swapped the cards with one that was laying around in the classroom, which happened to be the Rage 128 Ultra. The power supply is for sure Dell proprietary, judging by the arrangement of the wires.
Reply 935 of 5019, by kiwa
Yesterday i found a wyse vx0 thinclient
I mainly pick this things for the DOM, but i want to see what i can do with this thing.
The attachment tmp_10260-IMG_20170514_003041313913840.jpg is no longer available
Reply 936 of 5019, by candle_86
256mb Thumb Drive still in working order
Reply 937 of 5019, by clueless1
I still have a 128MB from years ago that I use as a DOS 6.22 USB boot. For running SpinRite and flashing BIOSes. 😉
Reply 938 of 5019, by infiniteclouds
Home shopping - found this in the basement. It was a Christmas present back in the 90s for my Nintendo 64 except... it wasn't for the N64 (despite the logo)... I didn't know what it was (gameport) supposed to be for at the time and it ended up getting stashed away, unused. I'm going to test it out now and hope it works without drivers because I don't have any.
iKSAgc4.jpg?1
Reply 939 of 5019, by TheAbandonwareGuy
infiniteclouds wrote:
Home shopping - found this in the basement. It was a Christmas present back in the 90s for my Nintendo 64 except... it wasn't fo […]
iKSAgc4.jpg?1
What the hell? How did something like that even get sold, hell even patented, without Nintendo hitting them with a corporate sized law suit?
