Matrox M3D / PCX2 opinions
Reply 40 of 78, by leileilol
I use a P4 with mine. 6th gen cpus can bottleneck its potential 320x240 performance in certain supported games 😀
FUCK "AI"
Reply 41 of 78, by gdjacobs
I use a 1200mhz T-Bird. Pretty sure the CPU isn't holding it back.
Reply 42 of 78, by AlucarD86
mhm interesting, can you please tell us your full setup ? I really had a hard time with the M3D on a Pentium 4 D 3 GHz.
PC Setup: Mainboard ASUS CUBX | CPU Intel Pentium III-S Tualatin 1.4 GHz | Memory 780 MB SDRam | Soundcard Creative SB Audigy SB0160 | GPUs Nvidia FX5900 Ulta Matrox M3D PCI | HDD 2x40 GB WD/Seagate | OS Win98SE and WinXPSP1 in dual boot
Reply 43 of 78, by leileilol
Nvidia cards are known to give the PCX2 a hard time. Try any non-vidia card instead
FUCK "AI"
Reply 44 of 78, by Rhuwyn
I've got a mATX Tualatin motherboard which has onboard video and no AGP slot so its been gathering dust. The onboard video is TridentBlade3D. This way I can make sure nothing is holding back the m3D, and still use this board I probably wouldn't otherwise use.
Thoughts?
http://www.biostar-usa.com/mbdetails.asp?model=m6vlq
Reply 45 of 78, by dr.zeissler
What games/demos/intros do only work with a powerVR-pcx1/2 and do not work or look worse on D3D/OGL while using intel i865 ?
Thx
Doc
Reply 46 of 78, by AlucarD86
I believe most of the PowerVR game counterparts look better and run at a higher resolution than their Direct3D versions. For a detailed list with all PowerVR games go here
Reply 49 of 78, by dr.zeissler
Tombraider1 for Dos seems to be great with PowerVR. But Turok1 is bad. The performance is not so good, some effects are missing even compared to the D3D-Version on my IGP i865 ist not good either.
Reply 50 of 78, by leileilol
Such as.........?
FUCK "AI"
Reply 51 of 78, by dr.zeissler
Background in the Intro behind the tree. In GLIDE and D3D it's moving and shaded, in PVR it's only flat, same with the sky in the entire game.
Reply 52 of 78, by Jerry79
Hi, this is an old thread i know but i remember reading a comment that the m3d is stackable.
Does anyone know something about that?
Is it even possible and if so is there a Driver?
I could not find any info or confirmation in the manual or other forums.
Reply 53 of 78, by Warlord
great necro, so you are telling us that you have more than 1? Cuz if u don't you wont find another.
Reply 54 of 78, by Jerry79
Warlord wrote on 2020-08-29, 22:43:
Yes i got my hands on two of these. Both got recognized by the win98se system just fine. With original driver and apocalypse tested.
No issues but although no gains in bench-marking with Quake-powerVR.
So, for me it seems the m3d is not stackable but maybe I'm missing something.
Reply 56 of 78, by GL1zdA
leileilol wrote on 2016-05-22, 22:17:
Tommaso72 wrote:
actually a 686mx 133
Speed on that won't be great either. The PCX2's drivers demand a strong FPU
What would be a good CPU for the PCX2? I've just installed a Matrox m3D into my Pentium (non-MMX) 200 MHz machine, run Final Reality and the results are way lower than Voodoo 1s in this machine: 1.21 vs 1.76 Reality Marks.
getquake.gif | InfoWorld/PC Magazine Indices
Reply 57 of 78, by NostalgicAslinger
A Pentium II 300 MHz and above should be able to utilize the card well. I use my Celeron 333 Mendocino machine for the m3D.
Reply 58 of 78, by leileilol
GL1zdA wrote on 2022-01-31, 12:21:
Period correctly, a Klamath P2 233-300 on a 440LX. Many Pentium II OEM systems towards the end of 1997 had PCX2s with them
Other than that, 7th gen stuff (Athlon, P3, P4) should be fine as there's a few games a PCX2 can handle better on those processors than the P2. You can potentially get through Deus Ex on one...
The aforementioned P4 + M3D gets 2.93 reality marks for the 3d test. It's not a very good test for pure 3d cardness as that ripple at the start's quite the CPU muncher
FUCK "AI"
Reply 59 of 78, by GL1zdA
leileilol wrote on 2022-01-31, 17:30:
Which OEMs used the PCX2?
It looks to me, as if the PCX2 was positioned in some really odd place. A $99 card that required a $600 CPU to make the most of it.
