Been having some fun with the machine and done a couple more things to it 😀
I had some I/O port/IRQ issues with my Music Quest PC MIDI card clone - I could output to it just fine, but couldn't receive input from one of my synthesizers. Windows 95 was detecting 3x MPU401s and the AWE32 MIDI interface, and device manager was showing problems - all kinds of wrong. The Music Quest diagnostics also guessed the correct port for the card, but it wasn't able to detect the IRQ, so I suspected an IRQ conflict.
The Music Quest card was set to port 330 and IRQ 2 (aka IRQ 9), where most old DOS games seem to expect it, whilst the AWE MIDI was set to 300 and IRQ 5 - no conflicts there. The culprit, it turns out, was my Tseng ET4000, which was also sitting on IRQ 2. The Hercules ET4000 card has a row of jumpers on the bottom, but they seem to be undocumented. I traced pin B4 (IRQ 2) on the Tseng card directly back to jumper J1 (if I remember correctly), so I set the jumper to open circuit.
I went back to Windows 95, deleted all the duplicate devices, did a re-scan, and two devices were detected properly - "Creative Labs Sound Blaster 16 or AWE-32" and "Music Quest MPU-401 Compatible". Bingo, all conflicts gone, Music Quest diagnostics working, and MIDI in/out working perfectly! 😀
Hopefully this will help someone else trying to mix the Hercules Tseng card with an older MPU401 or similar.
Next thing to sort out was the power supply. It was a bit too loud for liking - the PSU fan drowned out my modern desktop! 🤣
At first, I wondered if the PSU was worth replacing with something more modern, as it is branded "Perfect", which is a bit questionable. However, upon opening it up I found that it's actually a re-badged Bestec BPS-2004-4U, and some of the capacitors are quality Japanese brands (Rubycon). The consensus from a Badcaps.net thread seemed to be that the PSU is pretty good, so I decided to keep it and improve it. I'll replace all the capacitors at some point to freshen it up.
I decided to do a classic modification to the grill on the rear of the unit to reduce the noise and improve airflow. With some careful Dremel work, the results can be quite neat and look almost "factory":
The fan was replaced with a nice quiet Noctua NF-R8 Redux 1800RPM and the PSU finished off with a stainless steel grill:
The grill fouls the cutout for the PSU on the AT case, but I absolutely refuse to take a Dremel to the case, so the solution was to simply space the PSU back slightly with some washers. I think it's turned out quite nicely, and the PSU is much quieter, so at least I can hear myself think now 😀
Also did some cable management as best as I could, so it's a bit tidier inside now:
And finally, I took the advice of feipoa and installed a proper floppy drive in there. 😀 I quite like the "squareness" of the design of this Mitsubishi drive, and it's a good colour match for the case:
I *might* have sourced a 5.25" drive, but the seller has discovered some issues with it, so we'll see - he's currently trying to repair it.
Cheers!
