First post, by Cush
Hello,
I recently acquired a copy of the talking version of Loom and with VDMSound everything works like 95%. The voices start on cue and the music is fine and everything, but when I cast a draft, only the first note of the draft plays! Everything else on the staff lights up and the draft works, but the sound doesn't work after the first note. I can listen to them, just not play them back. I'm playing Expert mode as well. I'm using the latest version with Launchpad and system specs are in profile.
Cush
