Reply 17240 of 58966, by kithylin
xplus93 wrote:
kithylin wrote:
160GB IDE hard drive. It had a orange price tag on it. Found it bare hard drive with no static bag just sitting on the shelf with the rest of the junk in there. Orange tags were -75% off today. $0.85 after tax to walk out the door with it.
Working on testing it now.
EDIT: WORKS! Spins up, has a partition on it, read by windows.. performing slow error scan / surface scan with hdtune pro now. Only getting 37-38 MB/s over usb 2.0 but it's fine. Just leaving it going while I play games.
Good find. Too many HDs are destroyed "for privacy" these days.
Yes, I plan to do a boot`n`nuke on it later in another computer. But I need to make sure it's healthy first. Surface scan should take about an hour.. better to find out if it's bad before leaving a computer on for 4-7 hours to do a boot`n`nuke, only to find out at 90% it hits a bad sector.
Reply 17241 of 58966, by TheAbandonwareGuy
xplus93 wrote:
kithylin wrote:
160GB IDE hard drive. It had a orange price tag on it. Found it bare hard drive with no static bag just sitting on the shelf wit […]
IMO that's a pretty valid reason. I sure wouldn't want random Joe having access to my entire financial record and the average person wouldn't know how to properly wipe a hard drive. It's really too time consuming to be done in mass on old slow hard drives by the hundreds. Plus hard drives tend to have pretty long service life's and like all magnetic media they do decrease in reliability after a while.
Reply 17242 of 58966, by Unknown_K
A very good deal since it is a larger IDE drive and IDE drives are getting harder to find.
Reply 17243 of 58966, by kithylin
Left it scanning while I was watching "Angry Birds: The Movie" ... mmmm my first ever native 4K movie. Made my 3770K + R9 290X work hard for it, almost stressed gpu + cpu constantly.
160GB IDE Drive passed hdtune while I was watching.. and set it up on spare computer in the other room with boot`n`nuke and let it go for a few hours. Yay cheap IDE drive, decent capacity for an old system.
Reply 17244 of 58966, by mv_cz
The Serpent Rider wrote:
Typical Samsung UCCC DDR400 can run 2-2-2-5 DDR333 mode on stock voltage just as easily. In fact, even more older Samsung DDR333 256mb sticks were able to do it.
Yes, I've also had good results with RAM OC's troughout all my computers from SDR to DDR3. In fact my memory modules always able to run at step+1 frequency and those were no special modules. I picked these, not only for the price, but I like their heatsink. Bought similar hyperX DDR3 modules with blue heatsink for my main rig last year, kingston did not really change the design a lot 😎
Reply 17245 of 58966, by badmojo
brostenen wrote:
Bought a Commodore64 PLA chip and a socket for the chip. Hope I do not screw the soldering job up.
My machine begun to make some strange stuff. Poke 1,63 did not freeze it, and the diagnostic
program said that there are some timer issue and bad U5. Hope my reading is correct that it is the PLA.
I just chopped my old one off at the legs and de-soldered each leg - easier!
Reply 17246 of 58966, by appiah4
Kind of started collecting ISA audio cards; now I finally have a more classic SB16 in the form of a CT2290. Hope I didn't end up getting one of the worse versions out there.
I didn't notice that the bracket was warped on either end before posting; I have since fixed the bracket. more concerning however is that one of the capacitors near the amp chip appears to have imploded somehow. This needs to be replaced, right?
The attachment SB16Damage.jpg is no longer available
Anyway, next up is an impulse purchase, a GeForce 256 SDR. I replaced its fan with a cheap 3rd party cooler, and the original fan on this thing has now lives on cooling my GeForce 256 DDR.
Also grabbed a Pentium 233 MMX CPU to replace the 166 in my Socket 7 Voodoo 2 system. I think I've done all my retro spending on the first day of the month unless I come across any awesome bargains (currently hunting down a CHEAP Vibra 16S ISA card..)
Who am I kidding 🤣
Reply 17247 of 58966, by cyclone3d
Who am I kidding 🤣
Here is one on eBay for $19 + shipping. Depending on where you are, it could be a pretty good deal.
http://www.ebay.com/itm/Creative-Vibra-16S-Mo … G-/282487131168
and another:
http://www.ebay.com/itm/Creative-Sound-Blaste … 62/182569271512
and somebody has a bunch of new ones for cheap
http://www.ebay.com/itm/Creative-Labs-16-bit- … d-/391670743374
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 17248 of 58966, by brostenen
I think that is my plan as well. Does the C64 have brittle solderpads like SMD or is it a bit more roggid?
My plan is to solder in the socket, in order for easy access in the future. (and not to destroy the pads)
Reply 17249 of 58966, by badmojo
No I've found the solder on mine to be quite workable and easy to remove with braid, I just don't have the patience / skill to remove whole chips without cooking the board. Given there's a lot of room to move on the board I think chopping them is a good option (I used a dremel) and then you can simply heat one leg at a time and yank them out with pliers
Reply 17250 of 58966, by appiah4
cyclone3d wrote:
Here is one on eBay for $19 + shipping. Depending on where you are, it could be a pretty good deal. […]
Who am I kidding 🤣
and another:
I snatched a used 16S with IDE and OPL on ebay for 1 GBP plus shipping yay me!
Reply 17251 of 58966, by Cyrix200+
I got these nice parts:
Asus P2B-LS
Powerleap PL-iP3/T with Tualeron 1.2GHz
Pioneer DVD-105SZ (Slot loading DVD player - hope it still works!)
1982 to 2001
Reply 17252 of 58966, by Predator99
Predator99 wrote:
Just received this lot. […]
Reason to buy it was that I spotted a 80286 Suntac Board for my collection in the pile.
Most luckily it seems to be in almost perfect condition with battery removed before causing any damage 😀
Then there is a nice Socket 7 AT board
And 2 even more nice 80386 CHIPS boards. However the 82A306 Socket is destroyed in both 🙁 One chip is still in its socket, so I hope I will be able to repair it.
First I will test the Suntac 😀
EDIT: Arrrghh no the 2nd 386 Board isnt a CHIP but an INTEL...some idiot removed the 82A306 from the CHIPS board and put it in a socket of the INTEL board.... 😵 😵 😵
I just like to share that I managed to repair this board 😀
The attachment IMG_0039r.jpg is no longer available
Soldered a new socket and took the 82A306 from the other board where it was "installed" as 80387...
The cap right beside the socket is als destroyed and only the half left, but it seems to be working so I will not replace it.
The attachment DSC_6444.JPG is no longer available
8 MB of RAM in such an old board...wow!!
The attachment DSC_6443.JPG is no longer available
Reply 17253 of 58966, by TheAbandonwareGuy
Cyrix200+ wrote:
I got these nice parts: […]
Asus P2B-LS
That is a nice DVD player. It has that uncommon late 90s Retrofuturstic look. Beiege and slot loading. I also suspect it's harder on disks though.
Reply 17254 of 58966, by probnot
I found another 486!
I have an ad on kijiji looking for older PCs, and yesterday someone messaged me that he has one if I'm interested and sent me pics. It came complete and is very clean (no dust, all the fans are excellent, the 5.25 drive still has the cardboard dummy diskette!). Apparently this was his first computer, so I want to keep it fairly original.
ECS UM4890 1.1 Motherboard (with external battery)
486 DX4-100 (heatsink is glued on, so not sure if Intel or AMD)
64MB 72-pin RAM (4x16MB)
Winbond ISA I/O Card (not VLB)
SoundBlaster 16 ISA CT1470
Diamond Viper VLB Video card
SMC 10mbit NIC
Fujitsu M2684TAU 528MB HDDs (two of them!)
Unknown CD-ROM (connected thru SB16, looks like a Creative?)
5.25 Floppy Drive
3.5 Floppy Drive
Fujistu FKB4700 AT Keyboard
Microsft Intellimouse 1.1A Serial
AST 14" Monitor (not shown)
Panasonic dot matrix printer (not shown, will probably be recycled)
I really like this case. It looks a lot like LGR's wood grain 486 case. I was also able to use this AT PSU to verify that my other 486 still posts fine, so it was only the PSU that died 😀
Reply 17255 of 58966, by Cyrix200+
Man, that is a gorgeous system! Enjoy it!
1982 to 2001
Reply 17256 of 58966, by Batyra
Nice! wow!
I just collect the hardware — others make it run.
Reply 17257 of 58966, by dexvx
Wow indeed. In the US, is it just craigslist and recycling centers? What other options are there?
Reply 17258 of 58966, by Anonymous Coward
That case is in really good condition.
I would guess the CD-ROM drive uses the Creative/Panasonic CD-ROM interface (assuming you mean CT1740, and not 1470)
I would guess the CPU to be the AMD variety. At least, I remember back then it was really uncommon to find Intel DX4s outside of OEM systems (in Canada at least). It should be easy to determine by measuring the size of the L1 cache.
Reply 17259 of 58966, by probnot
Predator99 wrote:
I just like to share that I managed to repair this board :-) […]
What sort of soldering equipment did you use to repair that? It looks quite difficult...
