First post, by Azriel_Strife
Hi everyone, I have had 2 of these boards and both of them have had the same issue.
The first board posted ok for a while, and then stopped out of the blue. It would not maintain CMOS settings and after each post it would claim a bad cmos checksum and revert to defaults. The 3v lithium battery in the board was known good, and I even tried others.
The second board is doing the same CMOS checksum bad thing. Again, batteries are good and it's not throwing any beep codes. You can change anything in the CMOS, or nothing at all, and it will still revert to defaults.
I have my 5x86 amd 133 running at 160mhz (4x40) mhz with the voltage jumper set to 4v, it wont post on the 3v setting. I've also tried posting at 133 but still no good unless i'm at 4v. Though the CMOS settings are the biggest issue at the moment.
Any help would be very greatly appreciated!
