First post, by Jade Falcon
Rank BANNED
BANNED
This is something I always wanted to try. But never got around to.
Building a cutstom dos system without any OEM parts or parts bought in lots off eBay for a total price of 100$ or less.
I just got a cheap socket7 motherboard and thought I give this a try.
So basically I want to keep the cost at or below 100$ with parts bought from eBay.
I'm not including software or none system components like keyboards and monitors.
As of now I only have the motherboard. This will be a long project as I'll be hunting down both period correct 1997 and older parts and at a low price.
Performance and nostalgia is not a goll here. The only goll is to build a fully working late dos early 9x system for less then a 100$ Useing parts from 97 and back. The case will be a b****.
Parts I have as of now.
Panasonic FDD drive. $5
Matrox MYSTIQUE $9.95
2 sticks of pc133 32mb ram $8
Bigfoot HDD $7.50
200w psu 2$
Cd/PD drive 10$
No name at slot1 motherboard with 440lx chipset 14$
Budget spent: $56.45 $spend $43.55 left.
Notes about a the parts:
The PSU was listed with a starting price of 2$ with free shipping, I got lucky with it.
The Matrox MYSTIQUE was listing as a Matrox MYST-2gb got lucky there too.
Parts I have that may be used temporarily to set up the system.
A few round IDE cables.
Realtek nic for copping files
Parts I already have that I will be using.
Fdd drive, age unknown, I believe I payed about 5$ for it on eBay a long time ago.
PD/cd drive. I have no clue what I payed for it, maybe 10$? That sound about right?
Reply 1 of 49, by x0zm_
I've picked up quite a few S3 Trio/ViRGE cards for less than $5 USD each over the years, so that's a good possibility for a video card if you can find one. I've also seen quite a few under $10 USD ATI Rage cards from 1995-1997 on eBay before, so that's also a thing to look at. The Matrox cards sell for too much because they are probably being sold as spares for industrial PCs.
Hard Drive will be one of the most challenging I think, up there with the case. Finding an old one, that works, at a good price, and not have it damaged in shipping is a nightmare.
iirc, on one of Phil's latest videos he mentioned he had a 20% off coupon for Electromyne. You might be able to grab CPU, ISA sound card, possibly a video card and some RAM then combine postage and get it at a good price.
Reply 2 of 49, by PhilsComputerLab
Keen to see how you go with that budget 😀
For me it's the shipping costs that kill it unfortunately. A motherboard bundle, like board, CPU, cooler, RAM and a GPU is a good start though.
Seeing you already got the board, if you can get a complete PC with all the other parts like case, a PCI graphics card, an ISA sound card, an IDE HDD and ODD, then this should be quite possible.
Reply 3 of 49, by kode54
Wasn't the ViRGE the world's first "graphics decelerator"? It's probably fine if you don't need 3D performance, though.
Reply 4 of 49, by cyclone3d
If you don't want to have to deal with the nightmare of trying to get a working IDE drive, you can always get a SATA card. There are quite a few that should work just fine and are really cheap.
The Promise S150 TX2 or TX4 would be a good choice. Doesn't necessarily have to be sold by Promise, you just want one with the Promise S150 chipset.
As for building a system with parts off of eBay for $100 or less... might be doable, but will probably take a while to find parts cheap enough.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 6 of 49, by Jorpho
There is a fundamental contradiction here. You cannot say that your "goll" does not include performance and nostalgia and then throw in an arbitrary restriction like "parts from 97 and back". Especially if you're concerned about the case.
You can probably build a "fully working late dos early 9x system" with largely arbitrary parts that will probably be entirely adequate for a large range of games without having to account for such concerns.
Reply 7 of 49, by Jade Falcon
Rank BANNED
BANNED
Honestly I'd like to stay away from items listed as lots. In other words I'd like to buy everything separate for a bigger challenge.
I don't Fallow you on bit. The 97 and back deal in there to make things harder. No modern hhd, cd drives CF cards and cases will make things far more challenging.
My nightmare is a sata to pata card. I never had any good luck with them.
But who says I'll be useing ide? Maybe I'll use a ffd drive and a lady-120 or Zip disk drive? Or maybe scsi? No I'll probably use a ide drive if the budget allows.
Reply 8 of 49, by gdjacobs
Hmm... I think you're going to find it very difficult.
Reply 9 of 49, by Jade Falcon
Rank BANNED
BANNED
Indeed that's the point. I think I'll be fine until I get to the case. But who knows I may get lucky and find one cheap. The psu could be problematic too.
Reply 10 of 49, by cyclone3d
I am not suggesting a SATA to PATA adapter. It is a PCI SATA controller card.
Personally I cannot stand spinning rust for a boot drive anymore. Doesn't matter the system. I put SATA SSDs in all my old builds.
YMF7x4 Guide
Reply 11 of 49, by sprcorreia
So, a 1997 system under 100$? Shouldn't be that hard. Hell, not going high end you can probably do it well under it.
Reply 12 of 49, by Jorpho
So instead of aiming for "performance and nostalgia", you're just purposefully aiming to make things needlessly difficult..? Yes, I'm sure this will be a long project. Maybe you should also only bid on auctions starting on even-numbered days. 😜
Reply 13 of 49, by PhilsComputerLab
I think it's a fun project. Looking at these recycling shops, it seems quite doable. An AT case might be a challenge, but ATX cases can be had for little money.
Reply 14 of 49, by Jade Falcon
Rank BANNED
BANNED
Nore do I, lucky most hard drives are not made of steel/iron but aluminum.
Reply 15 of 49, by clueless1
You could get lucky and get a complete build at a yard or estate sale for much less than 100. Just have to be diligent about trolling the neighborhood.
Reply 16 of 49, by oeuvre
It's possible to find similar era complete systems around $50-80 shipped on eBay (I've done that numerous times).
Looks like your board is AT so finding an AT case would definitely be the most expensive part. Try finding that locally or ask around vcfed or Amibay. The rest should be fairly easy.
Here's an AT PSU
http://www.ebay.com/itm/Computer-Power-Supply … t-/361998184104
Drives should be around $8-12 each. Another $30 or so for sound and video, then tack on another $15 for RAM and CPU
Reply 17 of 49, by keenerb
Craiglist has an occasional hidden gem as well. I picked up a half-dozen 386/486/Pentium 1 systems, with two VGA monitors, keyboards, and assorted peripherals for less than $100...
Reply 18 of 49, by cyclone3d
"spinning rust" is just a nickname for hard drives. It isn't meant to mean it is made out of steel, iron, whatever.
YMF7x4 Guide
Reply 19 of 49, by konc
Since you're sticking to ebay and avoiding lots, I'd say that it isn't because of the individual shipping costs. But I'm curious to see how it goes
