First post, by m5215tx
- Member
I am looking into possibly building a pure MS-DOS 6.22 system with one of my Slot 1 boards I have. I have never done a pure DOS Slot 1 Pentium II system so I have a few questions.
Are some/most/all AGP cards fine for the low resolutions that DOS games typically use? I know PCI works great so I assume AGP in DOS will be much better unless there is some issue I don't know about.
Would a PII 233MHz CPU be fine for DOS games from around 1995 to the last ones that were released or would one of the faster PII's be better for supporting that era of DOS games?
With the use of the faster PII CPU's would using an ISA sound card have problems? I have the following ISA card options: AWE64, SB16 CT1740 (DSP 4.05).
Roland MT-32 (old), CM-32LN, SC-55, SC-88VL, MT-120, SD-35, SD-20, SD-80, SD-90
Yamaha TG100, TG300, MDF2, MU15, MU100, MU2000EX + PLG150-DR + PLG150-PF + PLG150-VL
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
