First post, by appiah4
What is the oldest mainboard and cpu combination that can run Steam (comfortably)?
Setting aside the fact that GOG installers can be unpacked to work on Win98 (to varying degrees of success) what do you think is the oldest mainboard and cpu combination that meets GOG installer requirements (WinXP?) comfortably?
Reply 1 of 16, by RJDog
Googling suggests that SSE4 is a requirement for Steam now... which means Intel Core processor. And likely Windows XP as you suggest, to run it in a semi-supported manner. I believe with modifications it can be run with lesser processor requirements?
Reply 2 of 16, by Jo22
I know, this is perhaps a stupid question, but.. does Windows 98SE support (use) SSE3/SSE4 at all ?
We once had a Pentium III w/ SSE and Win98SE, but I never really thought about this matter.
So what about context swichting ? Wasn't that a reason MMX was born in first place ?
All I found was this, but it only mentions SSE 1 for Win98:
http://softpixel.com/~cwright/programming/simd/sse.php
Reply 4 of 16, by PhilsComputerLab
My AGP test machine is an Athlon 64 4000+ and GOG games as well as Steam games can be installed and played.
I've installed GOG games on older machines as old as a Celeron (running Windows XP). I definitely prefer the GOG games without DRM, however installation of games can take quite long on older machines, I believe it's unpacking them.
Most GOG installers can run under 98/ME with KernelEx. To run Galaxy, there is a community patch / project. But I just connect a USB drive and install games that way.
YouTube, Facebook, Website
Reply 5 of 16, by DosFreak
Galaxy works on XP but you have to use an unofficial patch. It's on the GOG forums.
Make your games work offline
Reply 6 of 16, by appiah4
So the minimum is Athlon XP / Pentium 4 on Win XP for Steam and any CPU with Win XP (or Win98 with kernelEx) for GOG?
It's a crying shame GOG installers can't run on older hardware or OS'es.. I realize that the main value proposition is old games on new hardware but being able to conveniently install old games on old hardware would have been great..
Reply 7 of 16, by firage
I only use Steam on newer systems, but I seem to recall it requiring SSE2 nowadays, which would render the Athlon XP incompatible as well.
My big-red-switch 486
Reply 8 of 16, by appiah4
Ok, so the Athlon64 and Intel Core are the oldest that can run Steam then?
Reply 9 of 16, by PhilsComputerLab
Even if the installers would work, there are many potential pitfalls. GOG focuses on getting these games to work on modern machines, and this often breaks them for old ones. Some can be sorted out, others not.
Reply 10 of 16, by appiah4
Which is a shame.. I wish GOG had an option to download original disk/cd images as well as installers for modern hardware.
Actually.. Maybe we should request it from them?
Reply 11 of 16, by PhilsComputerLab
There are petitions already for this 😀 I don't think there is much hope in getting images...
A lot of people I know buy the games on GOG as a token, but get images from "other sources". It really is annoying, but out of all the imperfect legal options, GOG is still the best ones.
Reply 12 of 16, by dr.zeissler
100% correct! We need unprotected OLD GAMES to run on OLD RETRO-MACHINES.
Reply 13 of 16, by Oldskoolmaniac
I use one of my xp machines to install gog games and then copy the install folder to my 9x machines.
Motherboard Reviews The Motherboard Thread
Plastic parts looking nasty and yellow try this Deyellowing Plastic
Reply 14 of 16, by firage
SSE2 was first supported by Pentium 4's, so currently the oldest setup with official Steam support would be a P4 running XP.
Reply 15 of 16, by BeginnerGuy
I understand why they would do it, but there should at least be a legacy client. If security is an issue, just block it access from store / marketplace services. I originally played half-life on a Pentium III, now they effectively changed that to a P4/Opteron/A64. As an aside, Diablo II doesn't seem to work online on windows 98 anymore either with the latest patch. Very upsetting for people who want to enjoy on their original hardware!! 😒
Sup. I like computers. Are you a computer?
Reply 16 of 16, by calvin
IIRC, the client will actually work without SSE2, but the web views (store and profiles, etc.) will be broken. I recall them supporting an older version of CEF for those machines, but I guess they finally gave up.
2xP2 450, 512 MB SDR, GeForce DDR, Asus P2B-D, Windows 2000
P3 866, 512 MB RDRAM, Radeon X1650, Dell Dimension XPS B866, Windows 7
M2 @ 250 MHz, 64 MB SDE, SiS5598, Compaq Presario 2286, Windows 98
