My DEC 486sx LP
First post, by DeafPK
I took the time to clean up and reassemble this budget-oriented pc from 1993 / 94. At one point I had etchy fingers and wanted to put in a DX-33 or DX2 and more cache, but I decided to keep it low-end mostly just to see how it performed. Also, I did spend quite some hours of my childhood on an SX-25.
The machine and its parts. 8 megs of parity ram, 128k cache is integrated, S3 924 video card in 32-bit local bus mode. Also it has a Mozart sound blaster clone with a 2x Mitsumi drive that goes with it. Possibly one of the early "multi-media" bundles.
It's not fast for a 486. There were some ussues with the ram, hence some figures with only 4 megs. I will supply further performance details using the DosBench pack supplied by our good guy Phil.
"an occasional fart in their general direction would provide more than enough cooling" —PCBONEZ
Reply 1 of 3, by chinny22
Nice stock PC, nothing about it is highly desirable but that in itself is the beauty. Its a true representation of countless PC's in offices and Schools everywhere.
I would have scratched that itch and upgraded, your stronger then I am!
Always liked the "Pizza box" form factor, something about the dimensions are nicer then full height desktop cases.
Mitsumi drive is quite handy on systems with just the 1 IDE channel as well, wish mine still worked.
Reply 2 of 3, by DeafPK
I agree that it brings back memories of these cheap pcs in schools and offices. I also happen to like the compact form factor - actually I have a weak spot for powerful systems put in a sleek little box, that is when the components and power supply are fairly normal and can be replaced or upgraded.
So for some more benches - I think it can be interesting to compare this to a high-end 486 or even some 386 builds.
3Dbench - 13,5
PcPlayer - 3,6
Doom (for slow computers) - 2943 realticks
TopBench - 87
I also ran the full screen Doom bench but it suffered heavy lag, partly due to the slow read speeds from the CD-ROM drive (have the bench suite on CD).
Reply 3 of 3, by BSA Starfire
That is a great little machine! Glad you left it stock, not many left like that these days 😀 A real piece of history that has all but vanished.
