First post, by emosun
- Oldbie
I have a compaq 386n and it's missing it's hard drive and cable. The machine requires a strange edge connector ide cable to connect drives and I'm wondering where I can get one or how to make one , also , if the machine uses just normal ide drives.
Ideally i'd like the machine to be able to boot to a cf card but need to know if that's even possible? The end goal is to put a drive in it max out the ram and install an os.
