First post, by NamelessPlayer
- Member
When I play certain Glide games on my V2-1000-equipped legacy PC, the colors get messed up-as in what should be blue comes out red & vice versa-green seems fine, though. I've made sure the monitor cable was securely inserted, so that wasn't the issue.
The games I have this issue with:
-MechWarrior 2 OEM 3dfx Edition(with the batch file mod & early Glide drivers)
-Descent II(using the D2VOODOO.EXE-D2_3DFX does not have this problem, so I use that)
It just doesn't seem right playing one of the best-looking versions of MW2 with messed-up colors. It's also annoying when you realize that it runs much better than MW2: Mercs patched to 1.1, likely because of the use of Glide instead of D3D.
I'm currently using the FastVoodoo 4.6 drivers, but also have some 3.02.02 reference drivers ready to be installed.
Anything I forgot to mention that could help you crack this case?
EDIT: I fixed my own problem simply by remembering to use the batch file. While the game does have its proper colors now, performance seems to be cut down(likely due to downgrading the V2 to a V1 through SST variables.)
