First post, by nzoomed
Looks the same as in the photo in the link below with the manual:
http://www.philscomputerlab.com/biostar-mb-1433.html
I dont see any voltage regulator, nor do I see the jumpers required to lower the voltage.
Are there a few variants with this model?
Would be great if It was capable.
Is there such thing as a DX4-100 overdrive CPU with an onboard regulator? If so will this board still be able to run at 100 MHZ?
TIA
