First post, by xjas
I grabbed a 1U IDE RAID array (Dell PowerVault 705N) out of the trash hoping it would have something cool inside. Well, it did, sort of:
The attachment board1.jpg is no longer available
The attachment board2.jpg is no longer available
The attachment board3.jpg is no longer available
...an i430TX based single-board PC with a Pentium MMX & 128MB of SDRAM. Looks like IDE1-4 (along the long edge) are RAID ports controlled by the two Promise chips on-board, while IDE0 (far right side) *might* be a standard port that it could boot off.
Unfortunately there is no video chip or keyboard or I/O controller on the thing. I'm guessing it has nothing like a standard BIOS, although there is an EPROM that could be (labelled "70700102-001 Rev.A".) The only external I/O at all are an ethernet port & on/off switch.
Have any of you messed around with one of these? Is there any way to make it into more of a general purpose PC? I would love a self-contained Pentium board in this form factor, but not holding out much hope here.
If worst comes to worst I'll just salvage the PSU, CPU and RAM, but it would be cool to have the whole thing working.
Reply 1 of 13, by luckybob
unless you have a need for a small slow nas, i dont see any real use here.
still cool board though. i'd put it on a shelf for a bit and sleep on it.
Reply 2 of 13, by r.cade
Sounds uncomfortable... 😀
Reply 3 of 13, by xplus93
I thought I saw someone selling those recently. Wanted to buy it, but no money. Personally I like anything dell. If it's a purely ROM based system then there isn't much you can do unless it's been hacked. If you can boot a standard OS then it would make a great DOOM or Quake server. If you can boot off of the main controller then set up a drive to boot to a network console then if it works you can load it up with whatever you need. You could even use it as a basic firewall if you want.
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
Reply 4 of 13, by RJDog
Neat! It reminds me a lot of the old Cobalt Raq3 servers; like, really, a lot. I used to have a rack full of 'em.. I still have 2 or 3 of them. The Raq3 was also Socket7 but ran K6-2 processor. Standard PC hardware, but a really (really) custom BIOS with a built-in (non replaceable) boot loader. They would only boot off of an ext2 formatted hard disk and load a 2.2 or 2.4 Linux kernel. I had old versions of Debian 4 on them (replacing the custom RedHat based OS that was on them) but... thats about all they could do, just a basic, under-powered, headless Linux server. Certainly no DOS or Windows or anything else retro PC'ers like ourselves are generally interested in. Consequently the ones I still have are collecting dust on a shelf and have been for some years.
Neat hardware though.
Reply 5 of 13, by xplus93
If you are serious enough with retro hardware then the networking gear becomes interesting. It's an amazing feeling to have almost 40 years of computing all talking to eachother.
Reply 6 of 13, by Errius
IDE RAID is always interesting to see. I assume this was for small businesses that couldn't afford SCSI gear. What would it have cost?
Is this too much voodoo?
Reply 7 of 13, by luckybob
https://books.google.com/books?id=yhsEAAAAMBA … 0review&f=false
Reply 8 of 13, by Errius
PowerVault 735N [SCSI] = $10,000
PowerVault 735N XP [SCSI] = $12,000
PowerVault 705N [IDE] = $4,300
PowerVault 701N [IDE] = $1,200
Quite a difference
Reply 9 of 13, by lazibayer
It looks like a NAS with x86 processor to me.
Reply 10 of 13, by xjas
Welp, I ended up hanging on to the entire board for now, although I'll probably just harvest the CPU & RAM for something else at some point. It would be really nice if this thing had some kind of video out, but it is what it is. Incidentally I cut my finger on the pizza box which annoyed me enough to make me recycle it. Can't save everything. 😜
I do like old networking gear for some reason 😜 I'm still kicking myself for passing up a free Cobalt Qube 3 (similar to the Raq 3, also K6-based but 100% cuter) a while back. Ah well, I'm sure I would have gotten it set up and working, and then put it in the back of my closet with 80% of the other stuff like that I've gotten my hands on.
Did you figure that out from reading the first post, where I stated that was exactly what it is, or the thread title? Just curious.
Reply 11 of 13, by lazibayer
I read the manual from DELL and some internal pictures. It doesn't seem to have boot disk nor I/O ports like VGA, USB, PS/2. All configuration must be done over LAN. I reckon it runs on customized firmware. Not sure if the board can give you some I/O via the onboard pins or SSH access to the OS. Anyway according to the hardware features and configuration interface it's much like a customized NAS to me, rather than a full-blown x86 computer.
Just for curiosity... Is it regular MMX or tillamook?
Reply 12 of 13, by Errius
Are those IBM Deathstars?
Reply 13 of 13, by xplus93
Are they fully operational?
