First post, by Kahenraz
- l33t
Is anyone familiar with what case/motherboard I should look at if I want to install ISA cards in a 4U chassis? What kind of historical compatibility might I expect from this (such as consumer AT/ATX board sizes and power connectors).
Most of the boards with ISA slots are AT-era and I'm not sure if I can even fit those into a standard 4U EATX case. The idea is that I would like to buy a small rack at some point and plug a bunch of old ISA cards into it and log in remotely.
I'm currently looking at the IEC-822 case which uses a PBPI-14SA backplane. Documentation suggests that it works with an SBC but I don't know how it would be installed.
