First post, by martin939
I have trouble formatting 5.25 floppies to work on my IBM 5155 (XT). I'm using a Mitsumi 5.25 drive and every 5.25 360k floppy I format on it, gets unusable on the 5155...even if I take an existing flopping that was working before, add or modify a file to it, it already gives an error on the IBM but they DO work on the PC they're formatted on.
The 5155 uses a DD/DS Qumetrak 142 drive.
I've tried formatting within CMD under Win 7 x64 and through VMware DOS 6.22 and FreeDOS and also by using the plain format A: command and format A: /4 (360k) aswell.
I'm using a DFI Socket 939 motherboard and I've set the drive in BIOS to 360k / 5.25 inch.
