First post, by jcastle
I installed GLIDOS v1.32 and VDMSound2[1].1.0 and istalled Tomb Raider Gold. Everything was working fine (good graphics and sound). I played up to the beginning of 4th level (Tonb of Qualopec) then exited the game. Later when try to start the game it get to the Title screen, the book starts to turn then the PC reboots. This happens every time. I tried deleting GLIDOS and Tombraid and reinstallimg but the same. Any help would be great.
MB - ASUSTeK Computer INC. A7N8X-E REV 2.xx
pt - 2.10 gigahertz AMD Athlon XP
ram - 1024 Megabytes
video - NVIDIA GeForce FX 5700VE
sound - NVIDIA(R) nForce(TM) Audio
op - Windows XP Professional Service Pack 1 (build 2600)
This is part of GLIDOS if it helps.
Selected: Tomb Raider
Executable: C:\Tombraid\Tomb.exe
ExeSizes: 873739
CDCheckFile: data\Level10c.phd
DosGraphics: Yes
VESASupport: Yes
ControlJudderFix: 1
Resolution: 3
FullScreen: Yes
TextureOverride: Yes
Mp3BackgroundSounds: Yes
RedbookEmulation: Yes
James T Castle
Reply 1 of 3, by Snover
You are probably getting a bluescreen. Go to Control Panel > System > Advanced > Startup and Recovery Settings and uncheck "Automatically restart" under "System failure".
Yes, it’s my fault.
Reply 2 of 3, by jcastle
Thanks, I unchecked "Automatically restart", no difference.
James T Castle
Reply 3 of 3, by Snover
Start > Run "eventvwr.msc", look for any "Save Dump" (Dump Save?) entries. You maybe need a better power supply. You didn't give specs on that.
Yes, it’s my fault.
