First post, by JustRob
So I picked up this old PC and installed Windows 98 SE on it, wanting to use it for mainly dos games. But I'm a total newb and maybe I made a wrong decision.
This old thing has integrated VIA AC'97 sound, which I found doesn't work well for most dos games.
However, I did get it to work with some. Jazz Jackrabbit and Extreme Pinball both work when I select any of the Sound Blaster options in the Setup program, and Rayman 1 works if I use the auto detect thing it has built into the game itself, it then selects the Sound Blaster Pro sound card.
Then there's Doom. If I run the setup program and select Sound Blaster for the music, I still won't hear any music. But, sound effects work fine.
Skunny (I dunno if anyone even knows that game) refuses to play music even if I select Sound Blaster in the setup program, but like Doom, it plays sound effects fine.
Then there's Skyroads, which doesn't come with a setup file whatsoever, and doesn't offer any in-game configuration options. Once again, no music, but sound works fine.
So it seems that for most games music is the problem while sound effects generally always work.
I guess my question is, is there any way to get music to work across the board for all of my dos games? It seems really finnicky.
Reply 1 of 20, by Osprey
Doom uses MIDI music. Those other two games may, as well. That could be your issue. Perhaps you should try to find some old VIA drivers to install.
Reply 2 of 20, by gdjacobs
Doom also uses FM music which is what's being configured by choosing "Sound Blaster" for your music device. This could be a case of FM not working or the volume for that channel not being turned up.
Reply 4 of 20, by leileilol
collector wrote:
This forum is for old Windows games on modern systems.
Are you sure about that
FUCK "AI"
Reply 6 of 20, by gdjacobs
collector wrote:
This forum is for old Windows games on modern systems. Marvin, the Paranoid Android
One thing does not agree with the other.
Reply 7 of 20, by Stiletto
Moved to Marvin -> Sound, ya knuckleheads. 😜
do the Fandango!" - Queen
Stiletto
Reply 9 of 20, by JustRob
I think this is the motherboard:
http://www.uktsupport.co.uk/pb/mb/luna.htm
Also I'm running dos games in Windows, I tried to boot into dos directly but then I can't get anything to work at all.
Reply 10 of 20, by dr.zeissler
AC97 works in Windows quite well and in Dos while running under Windows98, BUT in plain Dos I did not get anything to work.
Here is my advice:
Deactivated the AC97 Sound an put this Pci-Soundcard into it: Terratec ESS Solo-1 ES1938S TTSOLO1-S Ver 1.1
It MUST be this card, no other.
Then buy that MIDI-Module http://www.serdashop.com/waveblaster and put it on the card.
Then you have:
- The best possible Solution for MSDOS. You have Dos-Drivers and therefore you have FM everywhere and it sounds pretty good.
- You also have SBpro Emulation and a lot of Games/Demos/Intros, especially the old ones that support only 8Bit-Dac work just fine, but not all.
- You also have Win3x Drivers as well, so "dingeling" in Windows 😀
- You have great sounding general-midi as well, and if you like use emm386 and use softmpu with the mpu401-interface.
I also recommend getting an Lpt-Dac on you LPT1 and connect it to the Line-In of the Terratec. I also a a Dos-Mixer to get all sources als loud as I want.
Best PCI solution I found out yet.
Greetings
Doc
Reply 11 of 20, by gdjacobs
Hopefully the Solo-1 runs with DDMA!
Reply 12 of 20, by dr.zeissler
mine works fine with TDMA
Reply 13 of 20, by Kamerat
dr.zeissler wrote:
AC97 works in Windows quite well and in Dos while running under Windows98, BUT in plain Dos I did not get anything to work. […]
Here is my advice:
Then you have:
Greetings
Doc
Actually the integrated VT1611A should work in DOS by itself, but the FM synth isn't very good. Also the Solo-1 should work even better than it does on your system, so no need for a LPT-DAC.
It should do by default. 😀
YouTube channel
Reply 14 of 20, by dr.zeissler
The Dac is the fallback for possible problematic sb-titles and demos/intros that support it.
Reply 15 of 20, by gdjacobs
Good, but DDMA is better. No base memory consumed. 😀
Reply 16 of 20, by dr.zeissler
I do not use any base memory.
Reply 17 of 20, by gdjacobs
UMBs?
Reply 18 of 20, by dr.zeissler
no, only himem is loaded, qemm386 only for games that support mt-32 (softmpu)
Reply 19 of 20, by gdjacobs
Hmm... shouldn't the TSR consume a bit of RAM when doing TDMA? DDMA and PC/PCI have no resident component, I believe.
