First post, by VirtuaIceMan
 - Oldbie
I've posted my extensive research into older games, to determine exactly when Nvidia broke support of earlier versions of DirectX. The sweet spot (if your card supports it) seems to be driver set 260.99.
Read my full findings here, and contribute if you can. I've also submitted it to Nvidia. Once in the past my continual resubmitting of bugs got them to fix the slow-down-then-lockup bug with transparencies in older games, but I'm not holding out as much hope this time!
https://forums.geforce.com/default/topic/5431 … -earlier-games/
