First post, by Cga.8086
I was given this voodoo 3 PCI card inside a mega pack of old VGA cards in a box.
it is a voodoo 3 2000 and what i liked about the card is that it is the PCI version. Not sure there but voodoo3 PCIs here are very rare here
http://www.vgamuseum.info/images/vlask/3dfx/v3200f.jpg
That is the picture of the same card i have, but when i tried it ( tried it on 2 different motherboards, one was socket7 and another one was pentium 3 370.
The card failed to work. Computer turns on and monitor stays black screen.
The simptoms are:
- When pc is powered on...the monitor stays idle, there is NO sound of the monitor (typical) sound of the monitor turning on when you power on the PC.
- Tried different pci slots, no go
- Tried another PCI video card, and the other video card works right away.
- I touched the heatsink of the voltage regulator on the upper part, and it not hot, just warm
- I touched the heatsink of the CPU, and it is not even warm.
So my question is, is there any way to save this card? any advice you can provide to test before it goes to the trash can?
- Should i remove all the capacitors and replace the 6 caps with new 10uf 16v caps?
- Should i buy another voltage regulator ?
- Should i send it to the oven for 10 minutes?
im really trying to save this piece of history from the trash.
Reply 1 of 13, by kaputnik
Begin by posting sharp high resolution images of your card. Plenty of people with sharp eyes here, who might spot missing SMD components, corrosion, burned chips, bulging caps, etc, that you've missed
Reply 2 of 13, by CkRtech
Hey Cga.8086,
To add to what kaputnik said, see if you can get some photos with really good lighting. Natural light works well. If you have to use artificial light, see if you can diffuse it a bit so it isn't causing a spotlight on the board. Take high res photos of the front and back. Try to get a few shots from different angles as well.
Also note that vogons allows image hosting in the threads. If you use the built-in file upload functionality, it tends to work better for accessing/viewing/zooming than something like imgur - which cuts off the in-thread photos depending on how wide your browser window is (or if you are on mobile).
Reply 3 of 13, by RJDog
I've seen this work a couple of times and usually only provides a temporary fix. I would recommend doing as the others say and uploading pictures to see if anyone here can spot anything amiss (I'm always surprised at the people here picking up a lot of non-obvious things just from photos) and saving baking for an absolutely last resort measure.
Reply 4 of 13, by Anonymous Coward
I had a voodoo3 card with a similar problem. I was able to resolve it by reflashing the BIOS.
There is a trick to do it. I forget the exact procedure, but it involved booting up with an AGP card with the voodoo3 in the PCI slot and running the flash software.
Reply 5 of 13, by meljor
If you are testing on a test setup without a case: please hold the card up straight when testing.
It sounds silly maybe but i have tested a couple of v3 pci cards that would not post when sitting loose in the pci slot but when i held it straight up and applied a little pressure they worked fine. Only had this with voodoo's, just like the pcb is a tiny bit thinner (they probably aren't).
At least try cleaning the pci connector. The ''oven trick'' is a waste of time with these cards imho.
Reply 6 of 13, by F2bnp
Before messing with the board, try this:
Get an eraser, preferably one of the classic ones with a red and blue side. Then use it on the PCI connector on the card. This has worked for me on multiple occasions, I even had a Voodoo5 that wouldn't post and used this neat trick to make it work again.
Sometimes, the contacts become really dirty, which is why this works. Hopefully, it'll fix your Voodoo3 as well 😀.
Reply 7 of 13, by Fusion
I have a V3 3000 PCI myself, I can compare to screenshots if you post some.
My V3 PCI gets a little wobbly when not in a case as well. Damn thing has been through a lot of crap though and is still kicking.
Pentium III @ 1.28Ghz - Intel SE440xBX-2 - 384MB PC100 - ATi Radeon DDR 64MB @ 207/207 - SB Live! 5.1 - Windows ME
Reply 8 of 13, by Cga.8086
Hi guys
here are some high res pics of the card i got
I also wanted to say that i already did the eraser thing, does not work
i also put the card straight, moved a little bit up, moved a little bit down, and no go.
I might try the BIOS reflash? so i have to use an agp card and also the pci card and try to reflash one of the bios found online for the vodoo3 2000 pci sdram
https://s26.postimg.org/nhf3tj06x/image.jpg
https://s26.postimg.org/vo73l3q9l/image.jpg
https://s26.postimg.org/wrr7x2awp/image.jpg
https://s26.postimg.org/zacwxqwmx/image.jpg
https://s26.postimg.org/gjaznl22h/20170916_200151.jpg
https://s26.postimg.org/45y5goce1/20170916_200205.jpg
Reply 9 of 13, by cyclone3d
Does capacitor C131 on the right hand side of the front of the board have a good connection? It looks crooked. Could actually be broken internally even if it is attached.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 10 of 13, by Cga.8086
it looks ok, looks curved because someone changed it, it is not the original, so there is more soder below
Reply 11 of 13, by Anonymous Coward
Cga.8086 wrote:
Hi guys […]
Hi guys
I think I found the instructions for reflashing (and BIOS images) on that website that was very dedicated to providing 3rd party support for voodoo cards. I can't remember the name, but I believe it may have been shut down (but an archive exists). I believe the flash software was not generic, it was specific to the voodoo3 cards.
Reply 12 of 13, by Cga.8086
Anonymous Coward wrote:
Cga.8086 wrote:
Hi guys […]
Hi guys
the bios files i was able to get them here
https://3dfxbios.cl-rahden.de/index.php?title … o3#Voodoo3_2000
the flasher i was able to get somthing here
http://falconfly.vogonswiki.com/tools.html
26 Oct 2000
Seraphic's 3dfx Flash-Recovery
Bootdisk Maker
Allows to recover misflashed 3dfx Cards
Source : http://www.v3info.de
it creates a floppy and asks you to use an agp card to boot.
maybe thats what you used.
Reply 13 of 13, by shamino
I don't know any specific measuring points, but try to find some sign of appropriate voltage(s) coming in and out of the heatsinked regulator, and maybe that 5 pinned component.
If you can find a datasheet for those components you might also get more of an idea of what they should be doing.
SDRAM chips should be getting 3.3v, I don't know what this GPU runs on.
If you're really careful, you can even look for GPU voltage(s) at the tiny SMD ceramic caps near or underneath the GPU. If you try that, insulate the probe so that only it's tip is exposed, so there's less risk of shorting anything. Put the negative probe somewhere easy and safe, like the slide bracket or just use the PSU casing.
Although, if the card shows up when you go to reflash the BIOS, that would imply it's getting power. I don't know how much of the card needs to be powered for the reflash to work.
Don't consider the oven thing unless you're about to throw it away, and even then, I don't know if it ever works on cards of this period.
