Reply 19320 of 52909, by bjwil1991
Bidded on a Commodore 64 on eBay and I won. The C64 has the reset button mod on It, which is like icing on a cake: top quality and faster than the power switch. I'm planning on buying the 1541 drive, Fast Loader cartridge, and video cable. Also plan on getting a mouse, joystick, and some games on cartridges and floppies. The reason why I'm going for the fast loader cartridge is how fast the floppy drive will go.
Reply 19321 of 52909, by shiva2004
Srandista wrote:
Funny fact though. This card is not working with HDMI monitors. If you try to connect HDMI monitor via DVI->HDMI adapter, monitor will stay in sleep mode, no matter what. With DVI, there is no problem. What's most surprising to me is, that with my 9500 with R300 chip, which is really similar to R400, everything works as expected, and I can transfer my video signal even in FullHD resolution. Even Win 98 installer have no problem with that setup. Just wanna let you know, if you will try to connect this retro card to not-so-retro monitor.
Today I was trying to capture some old ATI demos with a Game Broadcaster HD. First I hooked up a Radeon 9100 (just a rebadged 8500) with a DVI to HDMI cable and no luck, no matter what I do it doesn't show anything, it always says "Out of Range". Then I try via VGA, suppossedly more compatible with old cards and again no luck. After a pair of hours or so of frustration I swapped the card for a Radeon 9600 and "plop"... instant image. Fortunately the card is still old enough to run the demos I want 🤣.
Reply 19322 of 52909, by Kreshna Aryaguna Nurzaman
Munx wrote:
I'm sure many here would argue that this isn't retro, but...its DX10. Most modern stuff wont work on it anymore. […]
Geforce 9800GT - a re-badged 8800GT. For 3 Euros 😀
Already own an 8800GT, so if i can flash this one into an 8800 as well I could have a nice SLI pair.
Or might not even need a flash, if what I've read so far is true.
Funny it's easy to forget that such retro-looking GPU is DX10. Where was the last time we saw green PCB?
Kreshna Aryaguna Nurzaman.
Reply 19323 of 52909, by Vallenrod
Two new members of the family:
CT1320C
166.73 KiB
CT1350B Rev 4
150.84 KiB
Reply 19324 of 52909, by BloodyCactus
Id skip the 1541 drive and just get a uIEC or Ultimate1541
Reply 19325 of 52909, by Munx
The most recent greens I can think of are the 8 series gerforce cards from leadtek and some s939 motherboards from MSI. I don't really miss green PCBs as they kind of associate with "generic" hardware for me.
My builds!
The Underdog - The budget K6
Reply 19326 of 52909, by bjwil1991
Those aren't available on eBay, only overseas.
Reply 19327 of 52909, by BloodyCactus
quite a few sd2iec on ebay. store.go4retro.com is a valid place to buy from (usa located) for uIEC and lots of C= stuff.
Reply 19328 of 52909, by Batyra
just bought this unidetified AdLib Multimedia... I'ts not MSC 16... looks even simplier.
    357.12 KiB
    Unidetified AdLib Multimedia
Reply 19329 of 52909, by cyclone3d
Have another lot of soundcards on the way...
Mostly Creative. Gonna keep a few and probably sell the rest.
Sellers pic:
417.52 KiB
Also have an IBM Aptiva sound card S-16WP1/L with the original wavetable daughtercard. From the research I did before buying it, it looks to basically be an Acer Magic S23A in functionality minus IDE except for the wavetable part is a daughtercard instead of built onto the board.
Sellers pic:
288.12 KiB
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 19330 of 52909, by blurks
Stiletto wrote:
I worked at a refurbished computer reseller in the mid 00's in the US, and among many other things, Medion computers came through it for a limited time. I still have a Medion webcam - somewhere, at least, not in use. And yes, there's Aldi stores in the US. So my memory is that Medion did try to give "Medion USA" a go, but was ultimately unsuccessful.
Interesting, thanks for this information.
Reply 19331 of 52909, by boxpressed
Cool. When it arrives, can you post a pic of the daughterboard? That's one I don't have, and I'm curious what patchset ROM it uses.
Reply 19332 of 52909, by badmojo
That's a nice find, I have that one and really like that GM chipset. It should look like this I suspect:
Reply 19333 of 52909, by derSammler
Looks identical to the Hizon DB333, only with 1 MB ROM instead of 512 KB. Too bad it can not do any effects, making it sound very dry.
Reply 19334 of 52909, by Batyra
My today achevements:
- Casio GZ-50 GM midi module.
28.28 KiB
Casio GZ-50
- Tyan Trinity S1590 AT100 - new old stock. It came with K6-III+ 400 CPU
330.16 KiB
Tyan Trinity
- 2x identical 128mb cl2 100mhz dimm memory sticks 😀 - I know it's nothing special but I wanted theese from some time.
190.79 KiB
128 CL2
- MSI N1996 mATX super socket 7 (ALI) motherboard - with soundcard and graphics integrated. I came with AMD K6-2 475
329.65 KiB
MSI N1996 mATX
Reply 19335 of 52909, by debs3759
Batyra wrote:
Just clicked the link in your sig. It says the sale is closed, but I made an offer for the VA 503+ if available at my price 😀
Reply 19336 of 52909, by Batyra
debs3759 wrote:
Thanks 😉
I replied to your message 😀
Reply 19337 of 52909, by SW-SSG
"N1996" is a generic supplier code and not the actual model number; the real unique model should be printed here (something like "MICRO-STAR Model MS-####"):
14.46 KiB
Reply 19338 of 52909, by Kreshna Aryaguna Nurzaman
Same here. Too bad most of my favorite hardware have "generic green" PCB, notably 3dfx Voodoo5 5500. Well at least Sound Blaster AWE 64 Gold are partially brown.
Wasn't ATI who started the trend of non-green PCB by using red PCB?
Reply 19339 of 52909, by Artex
Let's not forget Gravis! 😉
