firage wrote:Could someone please measure the installed height from the AWE64 PCB to the top of the SIMM? Also give us the height of the module used. Thank you!
There's 33mm between the top ISA slot and bottom (non-shared) PCI slot. A flat enough PCI card might fit if the contraption is less than that, otherwise it takes a very low profile PCI card.
I've now measured it at 27mm all together with a 25 mm high stick, so there is a little bit of room there.
Also, I got my SIMMConn Revival today! Sweet! 😀
I have some 6mm heatsinks installed on my Voodoo2's and they're right there on top of the SIMMConn. My smallest 32MB piece just clears the V2 with nothing to spare.
Can't overstate how close it is, but it goes. Very cool. 😀
