First post, by Niezgodka
- Member
Are any sid players available for dos? I know Cubic Player plays it for sure, but is there anything else?
Same thing with d00. Can't find anything.
D00 player from Vibrants:
ftp://ftp.scene.org/mirrors/hornet/music/prog … rs/vibrants.zip
there are a few vibrants D00/D01 players around.
not sure about sid tho.
wrote:Are any sid players available for dos? I know Cubic Player plays it for sure, but is there anything else?
Try this: Sidplay DOS
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
I5 3470s /8G /GTX750Ti /HDA
...I've tried.
It plays .sid file when you change extension to .dat
Wow. That sidplay doesn't take sid but dats... strange.
For d00 formats, and much more, I found AdPlay v1.6
According to its doc, it plays:
A2M: AdLib Tracker 2 by subz3ro
- File format versions 1, 4, 5 and 8 are supported
- Unimplemented commands (version 1-4): FF1 - FF9, FAx - FEx
- Unimplemented commands (version 5-8): Gxy, Hxy, Kxy - &xy
- In version 5-8 files, some parts of the flags byte are ignored
- Only SixPack compressed and uncompressed files are supported
- ADL: Westwood ADL File Format
- AMD: AMUSIC Adlib Tracker by Elyssis
- BAM: Bob's Adlib Music Format by Bob
- CFF: BoomTracker 4.0 by CUD
- CMF: Creative Music File Format by Creative Technology
- D00: EdLib by Vibrants
- Bugs: Hard restart SR sometimes sound wrong
- DFM: Digital-FM by R.Verhaag
- DMO: Twin TrackPlayer by TwinTeam
- DRO: DOSBox Raw OPL
- DTM: DeFy Adlib Tracker by DeFy
- HSC: HSC Adlib Composer by Hannes Seifert, HSC-Tracker by Electronic Rats
- HSP: HSC Packed by Number Six / Aegis Corp.
- IMF: Apogee IMF File Format by Apogee
- KSM: Ken Silverman's Adlib Music Format by Ken Silverman
- Needs file 'insts.dat' in the same directory as loaded file
- LAA: LucasArts AdLib Audio File Format by LucasArts
- Bugs: Some volumes are a bit off
- LDS: LOUDNESS Sound System
- M: Ultima 6 Music Format by Origin
- MAD: Mlat Adlib Tracker
- MID: MIDI Audio File Format
- MKJ: MKJamz by M \ K Productions (preliminary)
- MTK: MPU-401 Trakker by SuBZeR0
- RAD: Reality ADlib Tracker by Reality
- RAW: RdosPlay RAW file format by RDOS
- ROL: AdLib Visual Composer by AdLib Inc.
- Needs file 'standard.bnk' in the same directory as loaded file
- S3M: Scream Tracker 3 by Future Crew
- Bugs: Extra Fine Slides (EEx, FEx) & Fine Vibrato (Uxy) are inaccurate
- SA2: Surprise! Adlib Tracker 2 by Surprise! Productions
- SAT: Surprise! Adlib Tracker by Surprise! Productions
- SCI: Sierra's AdLib Audio File Format by Sierra On-Line Inc.
- Needs file '???patch.003' in the same directory as loaded file, where
'???' are the first 3 characters of the loaded file
- Bugs: Some instruments are messed up
- SNG: SNGPlay by BUGSY of OBSESSION
- SNG: Faust Music Creator by FAUST
- SNG: Adlib Tracker 1.0 by TJ
- Needs file 'songname.ins' in the same directory as loaded file, where
'songname' is the song's filename without '.sng' extension
- XAD: eXotic ADlib Format by Riven the Mage
- XMS: XMS-Tracker by MaDoKaN/E.S.G
- XSM: eXtra Simple Music by Davey W Taylor
Very nice player 😀
Yes AdPlays is kind of front-end to AdPlug library that can play a lot of formats.
But you asked for a D00 player and the Vibrants player is the D00 player from the creators of the D00 format so it should be 100% accurate 😀
well vibrants made two players and they both play songs differently 😜 there is an older and newer player I think from them.
