Reply 19480 of 59318, by Ozzuneoj
Yay, the Diamond Monster Fusion I got the other day for $10 works great! I ran it through my usual battery of tests and it handled everything I threw at it.
The original Diamond fan had a slight buzz to it for the first 15 minutes or so, but after the card warmed up it is now very quiet. Overall, this is fine specimen of a Banshee. The card is pristine and there's just a tiny bit of dust in the fan. This is the only 3DFX card I own that has active cooling aside from my V5 5500s in PCI and AGP. It definitely seems like a good idea, given the scalding temperatures these cards reach.
Reply 19481 of 59318, by Tetrium
probnot wrote:
Also, noticed this on the bottom. […]
ntMcrhbl.jpg?1
Either it was a sample, or maybe just for sale in Canada only?
Iirc it had something to do with patents or copyright..something or so.
I don't think it's a sample.
My retro rigs (old topic)
Report spammers here!
Reply 19483 of 59318, by gdjacobs
Intel was going all out with their legal department around that time. It was the start of them trying to corner the PC market.
Reply 19484 of 59318, by bjwil1991
Bought a set of sealed floppies for $0.99 for 8 of them. Almost bought a Samsung VR 2016 version, but $74.99 at the same thrift store I got the floppies from, but it's a little too much. My S7 Edge is supported for it.
Reply 19485 of 59318, by liqmat
liqmat wrote:
Took this lot away for $10 from a newly discovered electronics recycle center within a quick driving distance from me. I'd say t […]
Took this lot away for $10 from a newly discovered electronics recycle center within a quick driving distance from me. I'd say that price was, well, amazing. There was tons more to cherry pick, but just didn't have enough time. The photos aren't great, but I do like the very early Sound Blaster SB2.0 8-bit CT1350B. Needs some cleaning. Anyone know what those empty sockets are for on the that card? Seems that this model has those empty sockets. Maybe for later upgrades?
Some of this will end up in my hardware giveaway thread shortly. If any of you have a use for the 486 SX-25 CPU, PM me. I have no idea if it works and have not tested it so install it at your own risk. I don't trade or sell. I give it away as you all know so not to break the rules of this forum. Just like to find homes for this stuff so it is preserved and not recycled into oblivion.
The MSI 745 Ultra (MS6561) motherboard that I purchased in this lot has a bulging cap next to the orange chipset heatsink. I have no time right now to do a recap and I am certainly not going to test it in that state. So if someone would like me to send them a motherboard that they want to recap themselves, it's yours. It looks to be in good cosmetic shape otherwise. Just PM me if you want it, otherwise it goes back to the recycle center. It will not have the CPU or memory in it. Just the motherboard and it's matching wire harness.
The attachment DSC02279.JPG is no longer available
Reply 19486 of 59318, by cliffclaven
So much empty green space on that AOpen board. Like a miniature golf course.
Reply 19487 of 59318, by TheAbandonwareGuy
PM Sent.
Reply 19488 of 59318, by Cyrix200+
ntMcrhbl.jpg?1
https://en.wikipedia.org/wiki/UMC_Green_CPU
In 1994, Intel alleged that UMC had infringed upon its patent for the 80486 microprocessor and filed complaints against UMC and it's distributors.[7] UMC countered the claims with an anti-trust suit and the case was eventually settled out of court with UMC withdrawing their product and ceasing production of 80486-compatible microprocessors.
As a result of the dispute, all processors were prohibited from sale within the United States and were visibly labeled as such. Placement of this label varies, the ceramic U5S and U5D models typically display "Not for U.S. sale or import" as part of the silkscreen on the top of the chip where the U5SX and U5SD models usually had "NOT FOR U.S. SALE" printed onto the golden die cover on the underside of the package. This labeling is often absent from plastic packages.
A nice piece of history 😀 Just like FDIV Pentiums etc.
1982 to 2001
Reply 19489 of 59318, by psychz
Received more PSX goodness: a SCPH-7502, two SCPH-5502s with sticker jobs, a SCPH-9002 (not pictured), a PSOne SCPH-102 (all modchipped), some original controllers, two Logic3 Justifier/GunCon-togglable lightguns, the PS2 IR receiver dongle, some cables (A/V, RGB SCART, SCART with breakout box), and a couple of games! The blackish 5502 came with a half-broken CD drive so I'm waiting for a new KSM440-ADM optical block for it. The 9002 is in almost perfect condition, as cool and quiet as a PSX can get while playing. They are all being thoroughly cleaned at the moment, one by one 🤣
Also got a rev 1.1 XBOX classic (Samsung drive) for dirt cheap. Came with the original Microsoft IR receiver on the fourth port. It powered on automatically when plugged and the front panel buttons weren't working. It had issues due to the clock aerogel supercap leaking electrolyte all over, destroying some traces. The first step was to get these lines reconnected with wire, as per this guide, to get rid of the front panel/power problems. Now the DVD drive needs some cleaning, as well as its rubber belt, since most of the time the tray refuses to open, and the last step will be a softmod or a TSOP flash, then a HDD replacement.
The attachment WP_20171010_002.jpg is no longer available
The attachment WP_20171010_003.jpg is no longer available
The attachment WP_20171010_004.jpg is no longer available
The attachment WP_20171010_005.jpg is no longer available
Stojke wrote:
Reply 19490 of 59318, by Batyra
Just got another "toy" to my GUS collection...
Compaq Ultrasound 32 Pro. - Clone of GUS PnP
The attachment Compaq Ultrasound 32 pro.jpg is no longer available
I just collect the hardware — others make it run.
Reply 19491 of 59318, by cyclone3d
Oh Goodie! The picture looks like it is the same as my card, with 256k RAM onboard.
Everywhere I look, it says it has 512k RAM onboard.
See my in progress guide for setting up the card here:
STB Ultrasound 32 Pro (Compaq Interwave sound card) - The comprehensive guide
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 19492 of 59318, by matze79
Uh a UMC 486SX 33 is fast as a SX40. If you clock it at 50Mhz it can even beat a SX2 66.
Reply 19493 of 59318, by liqmat
Got those boards for almost nothing and it ends up that the AOpen board is like a cross between the Gateway branded Intel BX boards and the Intel D815EEA that I lost recently due to a short. It worked out perfect for my Win98SE project. It has AGP 2x like the BX boards, but Socket 370 and an extra PCI slot. I yanked it from another case at the recycle center because all its ports line up with the Gateway case which has the back panel welded on. Ends up the AX33 is one of my favorite Socket 370 boards by accident. Very configurable in the last 2001 BIOS release R1.09. You're right, though, the board has a lot of green space. Unfortunately that short also took out my P-III 1GHz Coppermine CPU, but I have another one on the way.
Reply 19494 of 59318, by aop
Spotted this pile of trash in classifieds (picture is actually from the ad):
I instantly jumped on it and bought the entire pile. Reason:
https://i.imgur.com/1ZqhGk1.jpg
I wish it works, I just need to order an adapter online to test it out.
Reply 19495 of 59318, by ElectroMan
Reply 19496 of 59318, by lazibayer
Just FYI you can use a P&D -> VGA adapter if you don't need the audio ports.
Reply 19497 of 59318, by Ozzuneoj
aop wrote:
Spotted this pile of trash in classifieds (picture is actually from the ad): […]
I spotted that immediately. Nice find!
Honestly, those two boxed Radeons (assuming they are in there) are probably quite rare in box and likely worth a decent amount to collectors. I'd say those two are some of the few stand-out ATI cards from over the years. The 8500 was the first DirectX 8.1 graphics card and the 8xxx series were the only ones ever to support ATI's goofy "TruForm" tesselation, so if you want to see what your games look like when everything is made of balloons, that's one of the only cards that'll do it. And the 9800 Pro is obviously well known as a wonderful DirectX 9 card.
Also, the AGP card in the middle that's flipped over backward could be potentially interesting (or not at all)... I love those kinds of parts lots. Its like a treasure hunt. 😀
Reply 19498 of 59318, by chose007
Dont know what happened but I got lot of gold this month
need repair some bent pins but nothing big
finaly got socket 4 board, at start this MB f*k with me but now booting up
VGA for HP RISC
another fastest slot A
and lowest
and upgrade math cpu for Dell 386
Reply 19499 of 59318, by SW-SSG
Nice... so many goldtops...
