Doom 2 Loading Issues
First post, by uniracers
When I run Doom 2 in MS-DOS mode on my Windows 98SE PC, it hangs for about 30 seconds during loading on the part that says "Init DOOM refresh daemon". During gameplay, the disk icon shows up fairly frequently, and the game will stutter or pause for a brief moment when this happens. The strange thing is, if I run the game from within Windows without rebooting to DOS, I do not experience these issues. I have only noticed this issue with Doom 2. The original Doom seems fine. Is anyone aware of what could cause a DOS game to have differences in disk performance when run under Windows versus being run in DOS mode?
Reply 1 of 5, by leileilol
In DOS, the solution to help the disk access would be loading SMARTDRV. This isn't strange; it's how it's always been.
Reply 3 of 5, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
Reply 4 of 5, by uniracers
Thank you for your response. I tried adding SMARTDRV to the AUTOEXEC.BAT, and that seems to have made a difference in the loading issues.
Sorry for posting in the wrong forum.
Reply 5 of 5, by uniracers
In the Doom 2 manual, it specifically says "Do not use disk caching programs like SMARTDRV". I am running the game on an AMD K6/2 350 system which is at least 4 years newer than Doom 2. I would expect that the hard disk would be up to the task of running the game smoothly. Did you know something specific to Doom 2, or were you just suggesting that SMARTDRV will help with disk performance in general?
