Reply 40 of 122, by Kamerat
dr.zeissler wrote:
I have a "ready to go zip" simply put the card in a pci-slot and extract the drivers to your dosdrive, it should work ootb.
Can I put a Pentium4Mobile in that machine? the board is FSC-D1644. Does not seem to be compatible with a mobile P4 ?
Can you provide a link to that ZIP archive?
I usually don't care for official support as long as it works, I'm using a Pentium 4-M 1.6GHz in a Gigabyte OEM board from a Packard Bell/NEC computer. One concern is that Pentium 4-M lacks heat spreader exposing the fragile core.
YouTube channel
Reply 41 of 122, by Kamerat
sparky4 wrote:
ok and how do i use the ymfirq utility with out locking up my computer?
11:00.0 Multimedia audio controller: Yamaha Corporation YMF-724F [DS-1 Audio Controller] (rev 03)
i think it is an xwave 3000 or so i cannot remember completely..
Load it before the DSDMA TSR at least.
YAMAHA YMF724/744/754 patched dos driver for SiS63x/73x/745 (or later?) chipset users.
This driver does not need himem.sys and emm386.exe.
usage:
1. Keep IRQ 5 free.
2. Keep I/O 8000h free.
3. Run "setupds /s" in pure dos.
4. Run "ymfirq 5 edge".
5. "SET BLASTER=A220 I5 D1 T4"
Changes
September 7, 2002
- Added "edge" option to ymfirq.exe.
YouTube channel
Reply 42 of 122, by Kamerat
carlostex wrote:
@Kamerat
Do you mine trying Dune 2? I could never make it work with a YMF724, so i'm wondering about a 744. Problem was that as soon as a PCM sound was played during intro the whole system would lock up.
Tried it both in DDMA mode and with the DSDMA TSR. The game plays one sample and locks the computer but the music keeps on playing. Also tried disabeling L2 cache with the same result.
Setup:
Pentium 4-M @ 1.2GHz
GigaByte GA-8SIMLNF REV 2.0 (SiS 645DX/962UA)
512MB DDR
GeForce4 MX 420
Yamaha YMF744 (YMF-744B rev 10)
Edit: Gave the ALS4000 in DDMA mode a try on the same setup, seems to work fine.
YouTube channel
Reply 43 of 122, by sparky4
lowered MAXEXT to 458752 and running quake shareware crashs my pc..
should i go lower?
also if i use ymfirq it will always find the card and CRASH no matter what i put in.. (even if it is 0)
wwww
Reply 44 of 122, by sparky4
Kamerat wrote:
Load it before the DSDMA TSR at least. […]
usage:
1. Keep IRQ 5 free.
Changes
September 7, 2002
ok doing this right now!
wwww
Reply 45 of 122, by sparky4
no idea how to keep i/o 8000 free
i added "ymfirq 5 edge" just before the "dsdma" in loadtsr.bat
and it locked up my computer again with the same message
YMF724F found.
wwww
Reply 46 of 122, by sparky4
what could be the issue be?
wwww
Reply 47 of 122, by Kamerat
It only matters in DDMA mode I think.
YMF724F found.
Do you know what the actual PCI IRQ of the card is? You can try using that for your games instead. Have you tried to lower the physical RAM of your system and used EMM386 instead, try with 512MB if you got any small sticks.
YouTube channel
Reply 48 of 122, by sparky4
Subsystem: Yamaha Corporation DS-XG PCI Audio CODEC
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 41 (1250ns min, 6250ns max)
Interrupt: pin A routed to IRQ 20
Region 0: Memory at c2000000 (32-bit, non-prefetchable) [size=32K]
Capabilities: <access denied>
Kernel driver in use: snd_ymfpci
Kernel modules: snd_ymfpci
looks to be 20
I can look...
also ddma mode is needed for any soundblaster stuff to work at all!
wwww
Reply 49 of 122, by Kamerat
sparky4 wrote:
looks to be 20 […]
looks to be 20
Under DOS it should be assigned an IRQ of 15 or lower.
sparky4 wrote:
I can look...
No, YMF7xx can do PC/PCI or DDMA without TSR on compatible chipsets and motherboards or use the DSDMA TSR on boards that's not compatible with PC/PCI or DDMA modes. There's no DDMA support on Intels ICH based chipsets and later.
YouTube channel
Reply 50 of 122, by sparky4
how do i find out the IRQ in DOS?
so my ICH9 motherboard will never have sound blaster?
wwww
Reply 51 of 122, by Stretch
I use Craig Hart's PCI MS-DOS program
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - ESI Maya22 USB
Reply 52 of 122, by dr.zeissler
Sorry for that late answer. Here it is. ESS-Solo1 DOS ready to go.
The ESS works up to I865GV very well. From I915 upwards the digisound does crash/freeze the machine. Adlib works just fine. A Covox still works on I915, but the ESS in Digisound anymore. My fastest machine therefore is a P4/2,26 with I865GV (Scenic C610 ThinClient).
Reply 53 of 122, by dr.zeissler
argh! I can't get my ESS-Solo1-PCI working under Win98se with the I865GV chipset...I have to investigate, what the problem is.
Dos62 and Win2k is fine on that machine...I did not expect any problem with win98se...but I was wrong 🙁
Reply 54 of 122, by dr.zeissler
That's bad, really bad 🙁 The ESS-Solo1 PCI refuses to work on my I865G, while Win2k and Dos is OK.
I have installed the latest chipset-drivers for win98se and thy do work with i865gv pretty well.
The intel extreme-graphics2 drivers do work also, but installing the solo1pci vxd-drivers the PCI-Solo1 gets (!) and does not install the DOS-Emulation on restart. The Esssolo.ini is not installed on root, essolo.sys and essolo.com show an error because of that. If I use my working installation for the essolo.ini the bootup seems to be OK, but DOS-Emulation does not install, even if the bootup shows no error.
Deinstalling and using the newer vxd-drivers does not solve this problem. installing the wdm-driver leeds to a lockup (bluescreen) at startup. what is wrong here? 🙁 🙁
this is a very bad day...this machine was best so far. the igp is very good and has very solid and quality video-output. dgvoodoo works to with it. I am very sad that ess-solo refuses to work on that machine.
I will do further testing, because I have no clue why the ESS-Solo works in Dos/Win2k and not in 98se. It must be something special due to the machine or the chipset.
argh! 🙁
Reply 55 of 122, by dr.zeissler
I will put my YMF744 in that machine and we will see...
Reply 56 of 122, by dr.zeissler
YMH744...and it is much worse...no DMA under plain dos...no way better...I think there is no way of getting the ESS-Solo1 working under win98se on i865gv...
Reply 57 of 122, by sparky4
i had have no time to see what value is the pci card is
and i will not until quarter is over. or in 3 weeks
wwww
Reply 58 of 122, by sparky4
where is the pci utilities? i cannot find them online
NVM I FOUND IT! and omg!!! it detects PCIe devies too!?!? whoa!
wwww
Reply 59 of 122, by sparky4
very interesting the ymf card of mine is assigned IRQ 5, INT# A
wwww
