Reply 19720 of 58199, by BitWrangler
Jade Falcon wrote:
Ebay.
Keep in mind it will look like crap most likely. S-video on alot of cards where not the best as with s-video the output is filtered on the card and the TV. and most cards even top end cards used junk setups for s-video.
You far better off with a TV with VGA or a old AIW card.
Back in the day, I hooked up a similar era nVidia to a similar era TV, @800 x 600 it was "muddy" on the desktop and hard to read, looked like you were viewing a monitor through a fish tank that really needed cleaning.... however, you didn't notice this so much in a game, where it worked like 4xAA, but still kinda blurry/dim. ... and yes I think you could get crisper output on older TV outs.
Reply 19721 of 58199, by appiah4
Can anyone ID this motherboard from seller's potato shots? I may be interested in getting it with the 800EB and RAM on it if it's a Tualatin board with ISA.. He asks only $10 for it, though it's "untested".
Reply 19722 of 58199, by Cyrix200+
<snip>
It looks quite beat up, corroded and dirty. It's hard to make out, but I don't think the type number on the north bridge ends with T, so it probably isn't Tualatin capable. But you don't need Tualatin support for a 800EB.
1982 to 2001
Reply 19723 of 58199, by LHN91
That kinda looks like an ASUS CUV4X or similar board.
VIA Chipset Asus board, at any rate, is my guess.
Reply 19724 of 58199, by appiah4
I see.. I already have a 733EB and the CPU would be a marginal upgrade at best, it could have been usefil if it were a 440BX Socket 370 though.
Reply 19725 of 58199, by BitWrangler
Gah, those days when you remember that MOBOT on motherboards dot org was useful sometimes... I am not sure if I'm seeing an MS number above the AGP slot in top pic, looks kinda like it, but not finding pics of likely suspects to compare.
Reply 19726 of 58199, by bjwil1991
appiah4 wrote:
Can anyone ID this motherboard from seller's potato shots? I may be interested in getting it with the 800EB and RAM on it if it […]
According to my Google research, I found the board information. It's a soltek sl-65kv2t with a VIA VT82C694T AGPSet, based on the VIA Apollo Pro133T chipset, and VIA VT82C686B I/O chipset with a VIA AC'97 Audio (Sound Blaster compatible for DOS). Supports up to 1.5GB SD-RAM, Pentium III, Celeron, and Cyrix III processors. The AGP is a 4x, and it's backwards compatible with a 2x AGP card (by disabling the 4x mode in the BIOS).
Slots:
1x AGP 4x
1x AMR (Audio Modem Riser)
5x PCI
1x ISA
3x SD-RAM PC-100/133 RAM Slots
Socket 370
Kind of odd that the board has DIP switches (mainly for the clock speed of the CPU that's installed <-- FSB * Clock Multiplier). It also looks like the board's seen better days. A good cleaning can make a huge improvement. Here's the PDF of the motherboard: Soltek SL-65KV2-T Motherboard Manual
Reply 19727 of 58199, by Cyrix200+
<snip>[
/quote]
<snip>
I think that is a different board, the ATX connector and the CR2032 are in a different location. Looks a lot like it though, so it might be a different revision and/or type by Soltek.
1982 to 2001
Reply 19728 of 58199, by martin939
I've got a 3Dfx Voodoo 1 PCI on a beautiful black PCB, any idea if it's worth anything?
It looks like this but mine has 2 heatsinks on the chips, looks original (and pretty "mint'y"
http://www.vgamuseum.info/images/palcal/3dfx/ … 65a4_top_hq.jpg
Reply 19729 of 58199, by Munx
ALL 3dfx cards are worth something. Having heatsinks is even better, since Voodoos get pretty hot and you don't want to lose this sort of hardware to heat.
I have the same black card from A-Trend with dual heatsinks and judging from the cooling solution and fast memory (83MHz when the default is only 50)I think they expected people to overclock them.
EDIT: I assume yours looks like this?
The attachment P_20171014_182337.jpg is no longer available
Anyway, they are really fun cards to mess around with and are a great edition to any socket 7 build and mid 90s games.
My builds!
The Underdog - The budget K6
Reply 19730 of 58199, by ElectroMan
Reply 19731 of 58199, by TheAbandonwareGuy
Jade Falcon wrote:
Ebay.
I have an Savage2000 with native composite out but I don't want to use a rare card for displaying Doctor Who. Where on earth would I find a CRT TV with VGA?
The whole point is a more authentic vintage TV viewing experience.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 19732 of 58199, by BitWrangler
There was actually a couple of years, end of CRT era when you could get high def tube TVs, with VGA input. But yah, these aren't the droids you're looking for.
Reply 19733 of 58199, by Jade Falcon
Rank BANNED
BANNED
TheAbandonwareGuy wrote:
Jade Falcon wrote:
Ebay.
Technically just about every CRT TV from the 90s on words had VGA support. If It has a OSD is has VGA support. But using it is not fun, you have to tap into the OSD chip. But I do recall some sony tv's having RGB inputs, Anything with RGB can be taped and used with VGA.
That aside I'd just buy a AIW card they are not hard to find and will look alot better, or at lest that's been my experience. Or a old Xbox with XBMC or maybe a dreamcast with the xvid player and hdd mod. Or even better a raspberry pi with XBMC. you have a lot of options here.
But the simplest thing would likely be the s-video cable for the 5950. If I recall you need a cable like this.
https://www.ebay.com/itm/New-Nvidia-Compupack … UwAAOSw42dZF5Ha
Reply 19734 of 58199, by liqmat
liqmat wrote:
Couldn't resist a 5950 Ultra for $10 and change on Ebay. Had a massive Zalman copper cooler on it that was bending the PCB. Remo […]
Couldn't resist a 5950 Ultra for $10 and change on Ebay. Had a massive Zalman copper cooler on it that was bending the PCB. Removed it and replaced with the original cooler that I restored back to working condition as I prefer everything original. Ebay description stated the original cooler fans had stopped working. Nothing a little oil can't solve. Spinning like new. Anyone interested in the Zalman cooler PM me as I have no use for it. You know the drill, I pay for shipping to keep the Cigarette Smoking Man happy. Has to be a U.S. shipping address.
I was surprised to find the 5950 Ultra was not much faster than my non-Ultra 5900. Maybe my 2x AGP port holding it back? Will find out with some testing I suppose. I would like to grab a Gainward 5950 Ultra Golden Sample one day as it has the red LED fans. Used to own one back when they were new. Should have kept that card.
Ok. So still no takers on this GPU cooler. Anyone who wants it free and clear go ahead and PM me. Refer to my post here:
Reply 19735 of 58199, by Jade Falcon
Rank BANNED
BANNED
aren't those LEDS suppose to be red.
Reply 19736 of 58199, by Munx
How are you supposed to cool hardware with red LEDs? Blue LED fans reduce heat while red ones make processors run faster (and much hotter).
My builds!
Reply 19737 of 58199, by derSammler
I own that one too, new-in-box, it's a "A-Trend Helios 3D". It does not come with heatsinks. If ones are attached, they are not original.
Reply 19738 of 58199, by Munx
Googling A-Trend Helios 3D shows a lot of models with heatsinks and some with no heatsinks having epoxy residue on the chips, which makes me believe that at least some were sold with cooling attached.
My builds!
Reply 19739 of 58199, by liqmat
I know the Golden Sample models have the red LEDs, but this 5950U non-GS has the blue.
Reading a review from neoseeker.com apparently the box says the Ultra has cool blue fans, but their review model had the red. My Golden Sample model back in the early 2000s also had the red. This 5950U I got off Ebay has the blue for some reason. Not really worried about it. It is missing the metal bracket on the backplate heatsink that attaches the two screw poles, but I don't think that will pose a problem.
From the neoseeker.com review:
"Also of note is that the fans have 3 red LEDs in each one. On the box, it says that the LEDs light up in a "cool blue", but we think that red was a much better choice to go along with the flame motif on the heatsink. "
