First post, by buckeye
This is my 1st foray into the 3DFX world having just got (2) Creative 3D Blaster V2 cards with both cables. Can someone advise me on which drivers to get and the installation procedure? I keep seeing the Fast Voodoo and then the latest 3DFX drivers being mentioned, so which one? My main card is an Hercules 3D Prophet GF2 GTS AGP version if that matters somehow. See my sig for the W98 set up if needed.
Reply 2 of 3, by meljor
Use the fastvoodoo driver. Google ''voodoo2 sli'' and see the images, it will show how to connect the cards.
Does not matter what other card you use, so Geforce2 is fine as well.
Reply 3 of 3, by Davros
I would just install 1 card first and if it works ok install the other one
dont forget to join them with the ribbon cable and make sure the passthru and monitor cables are connected to the correct card (both connected to the first card)
