First post, by Jade Falcon
Rank BANNED
BANNED
So I have a set old Stanton Dynaphase 60's and I need to change the crossover caps
I was wondering if changed the UF rating how would it affect sound? I never really played with changing out crossovers other then exact replacements.
This is a photo of the inside of one of the cans.
Reply 1 of 8, by luckybob
https://www.parts-express.com/resources-cross … selection-guide
or
http://www.carstereo.com/help/Articles.cfm?id=1
also MF like how they have it is the OLD way of saying MICRO farad. today's standards use µ
Reply 2 of 8, by Jade Falcon
Rank BANNED
BANNED
luckybob wrote:
https://www.parts-express.com/resources-cross … selection-guide or http://www.carstereo.com/help/Articles.cfm?id=1 […]
or
I do know the MF and UF are more less less the same. And thanks for the links. Seems to be everything decent I can find in the right size and rating seems to be too small. Oddly smaller caps don't play well with the set. I tried a few 47uf 16v caps and the smaller the cap the more they disport the sound.
Reply 3 of 8, by luckybob
are you using non polarized? I think that matters quite a bit.
Reply 4 of 8, by gdjacobs
The crossover components appear to be in series, so the capacitor will be acting as a high pass component. The critical frequency will be omega=1/(RC) or f=1/(2*pi*RC). Therefore lower frequencies will be passed to the coaxial tweeter when higher capacitance components are used. Also, higher ESR will decrease attenuation and pass lower frequencies to the tweeter.
Yes, this should be a non polarized capacitor, as the circuit is unbiased.
Reply 5 of 8, by Jade Falcon
Rank BANNED
BANNED
I'm using bi polar, its what I had sitting around.
after messing around with a few different caps I found that a 4.7uf cap gives the cleanest sound, less bass but cleaner sound none the less.
Higher capacitance tend to just distort the sound. more so on the right speaker.
Reply 6 of 8, by Jade Falcon
Rank BANNED
BANNED
Yes your right on with how the cross over works
Reply 7 of 8, by Matth79
If you can get non-electrolytic in the size, that may give better results than bipolar electrolytic
Reply 8 of 8, by Jade Falcon
Rank BANNED
BANNED
Yeah I was thinking of getting film caps.
