First post, by Jed118
- Oldbie
Hello all,
I have an AT board (286/16, I recently built it in an ESCOM box) that I bought had a severe leak on it - I cleaned it up and replaced the battery, and it worked. For a few months.
This is the board:
http://th99.classic-computing.de/src/m/U-Z/33124.htm
Now it'll POST like usual, but there is a Keyboard Error. The Keyboard does light up its LEDS upon start, but I think there's no clock signal getting to the keyboard controller from the onboard 8042.
Does anyone know what the DIN pin 1 connects to on the motherboard side? Which IC or other component feeds the clock pulse? I've probed around this board with a multimeter set in impedance mode and I can't get any indication of where it goes. I especially concentrated around the crystal area. All other pins go somewhere: I checked ground and VCC and those are fine. As well, the DATA pin on the DIN plug does go to PIN 39 on the MBL8042H keyboard controller. I can't for the life of me see where pin 1 connects to, and I've tried on another 386SX non-posting board I have lying around. I unsoldered the DIN connector from the board and cleaned it up, resoldered it, and that did not help.
Another weird thing too - This motherboard has the option of External Keyboard - I can't map CLOCK to it either:
Seriously, where does the CLOCK signal come from???
What's for sale? my eBay!
