Reply 7120 of 30429, by BitWrangler
Not using that, but I did use the case turbo button to directly operate on clock jumpers, and multipliers before (Switched it between them to try) and it didn't seem to mind that the short was now a 20 inch round trip.
Reply 7121 of 30429, by kazeobi
Inserted COASt cache module in my Siemens Scenic 5H PCI today. I don't if this cache makes difference in games, but POST message about 256 kilobytes makes me feel better, even if it is like being ricer 😀
Reply 7122 of 30429, by badmojo
I finally got around to testing this NOS VLB VGA card I bought a while back and it turned out to be decent, despite appearing to be a cheap-ish implementation of the S3 805 chipset. Nice image quality and fast enough for the 486SX 33 I'd be running it in.
Not pictured but I happened to have a Trident VLB card hanging on my outdoor toilet wall of dead hardware that had 2 X the exact same NEC memory chips that this card takes, so I was able to take it up to the full 2MB 😎
Reply 7123 of 30429, by Deksor
Are you sure you enabled the cache ? For heavy games, you should definitely see a difference if you had 0 cache before that. Use cachechk or speedsys to know if your cache is functionnal
@Badmojo are you going to dump that floppy disk ? It may hold interestind data ^^
Reply 7124 of 30429, by badmojo
Yep it's on my to-do list next time I have a machine out with a 5 1/4 floppy drive.
Reply 7125 of 30429, by KCompRoom2000
Since I remember the two 3Com 3C905B-TX PCI NICs I have for spare were rather picky when it came to 9x driver support in the past and the RTL8139 has terrible NT3.51 drivers (in my experience), I decided to test one of the 3Com NICs on my P1 rig to see if it was a viable alternative to the RTL8139 that's currently in it. It works great on all three OSes I use there (which are MS-DOS 6.22, WFW 3.11, and NT3.51) to the point where I was able to sort-of do some internet browsing on both Windows versions whereas the RTL8139 would only work on DOS and WFW but not NT. I guess I'll put the RTL8139 into my Win95 C433 build and use the 3C905B-TX on the P1 build as soon as I get a couple things to finish them off.
Reply 7126 of 30429, by probnot
badmojo wrote:
[..]Not pictured but I happened to have a Trident VLB card hanging on my outdoor toilet wall of dead hardware that had 2 X the exact same NEC memory chips that this card takes, so I was able to take it up to the full 2MB 😎
I...need to see this.
Reply 7127 of 30429, by BitWrangler
Also the bit about filleting a Trident card for the RAM it never deserved, muhuhahahaaaaa...
(Okay, tbh I have a Trident TGUI card that's alright, powered it up once and the house didn't explode or anything.)
Reply 7128 of 30429, by TheAbandonwareGuy
The standard in this community should be to pass dead hardware onto people who can fix it unless its something obviously unfixable even by the most skilled user.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 7129 of 30429, by Mister Xiado
Tech which displeases me dies in fire, or takes a ride on the business end of my 12 gauge. I have a SoundBlaster that needs some solder work, when I can cheaply source fewer than a THOUSAND surface mount capacitors, and when I can determine the values for the caps that were scraped off of the board thanks to the United States Package Smashers beating up every envelope I get from Russia.
Reply 7130 of 30429, by gdjacobs
Not worth fixing, bro. Friends don't let friends use Trident.
Reply 7131 of 30429, by TheAbandonwareGuy
Its interesting from a technology science standpoint. What if in 20 years you want to study the low end from that time frame? And not everything trident made was garbage. They did make some nice budget 3D accelerators in 1997-1998 that were near RiVA128 speed.
Reply 7132 of 30429, by BitWrangler
Plus nobody has recognised their value as a video decelerator, when your pentium system is still a bit too fast for a 286 game. 😁
Reply 7133 of 30429, by mongaccio
I've finally troubleshooted my faulty 1541 disk drive. Leds indicated that the logic was working, but motors refused to spin.
The 12v line was shorted, but the 7812 was fine. (one of the 2 big metallic transistors on the right)
Tried changing and testing some capacitors and diodes near it, on the 12v line, but all were fine. I was giving up, the i read on a 1541 troubleshooting guide that sometimes the c15 tantalum capacitor,also connected to 12v is the culprit .
Capacitor c15 is located on the far side of the logic and power board. Removed it and it was indeed shorted. Had a similar capacitor around , swapped it and the disk drive came back to life!
The attachment 1541.jpg is no longer available
My next big project will be a complete ic removal and socketing of a c64 board. I have 4 commodores 1st type, none is working properly. I must gain some knowledge in desoldering, first. I can desolder most 2 pin o 3 pin stuff, but ics are a nightmare.
Maybe with the right tool? I won't mind spending a bit of savings in a good desoldering gun.
Reply 7134 of 30429, by badmojo
Uh ha - so you want me to ship my dead Trident all the way to whatever planet you live on? That’s gonna cost you.
I have enough trouble giving away working hardware.
Reply 7135 of 30429, by JetSetWilly
Setting up an experiment with a Pentium II 233Mhz underclocked to 133Mhz, Intel BX Asus motherboard, Voodoo 3 3000 graphics and SB16 CT2230 sound card. Just gathering some spare pieces of hardware and see how they manage DOS games. Nothing fancy but enjoyable nonetheless.
Reply 7136 of 30429, by BitWrangler
JetSetWilly wrote:
Setting up an experiment ....
Careful man, you never know what might....
Uh oh.
Reply 7137 of 30429, by JetSetWilly
BitWrangler wrote:
Careful man, you never know what might.... http://l.j-factor.com/gifs/AnotherWorld-Lightning2.gif […]
Uh oh.
Fortunately, it´s everything under control 🤣
Reply 7138 of 30429, by Jade Falcon
Rank BANNED
BANNED
Paintied an ls-120 drive to match my case. Not my best work, but its cold here so it would never come out perfect.
Reply 7139 of 30429, by Mister Xiado
4th set, and still more games that I can't open or run from within Windows 3 on a 66MHz 486 DX2.
The attachment xiadoic4.gif is no longer available
