First post, by Neville
I'm trying to get the game "Colony 28" working with DOSBox, but I seem to be running into a problem while installing. Here's a capture of the screen:
These are my mounting settings:
mount C "C:\Colony 28 CD-ROM"
imgmount D "C:\Colony 28 CD-ROM\Colony28.iso" -t iso
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
FYI, you can type the words, even without accents/diacritics, into Google's translation feature to get a sense of them. Not so easy with languages using a non-Roman alphabet, of course. In this case the error message is: Unable to create directory on the target drive!
The installer may have some issue with a multi-directory path (perhaps GAMES must already exist). It looks like you can use the first option on the installer menu to change the install target to just C:\C28, which might be less problematic.
Reply 2 of 2, by Neville
Yes! This was exactly the issue. Thanks for the Google tips and the answer.
