First post, by andreja6
I know that Sound Blasters and compatibles can play some relatively amazing and detailed sounds (even played some really cool FM synth midi sounds through Windows 98) , although such probably was not that easy to do through program due to lots of CPU usage... I wonder if it is possible today or even if such a program actually even exists?
Reply 1 of 6, by cyclone3d
The PCM sounds are going to be pretty much the same no matter the card. 8/16/mono/stereo are really going to be the only difference.
The FM music (Yamaha OPL2/3) is also universally the same as long as you have real Yamaha hardware no matter the card.
DOSBOX emulates a lot of stuff so there is that.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 6, by andreja6
I didnt really write it out right. I meant to ask if there was software that emulated MPU-401 on sound blaster compatible cards using PCM/FM Synth
Reply 3 of 6, by keropi
you mean something like a "virtual midi device" ? such things only exist under windows
Reply 4 of 6, by keenmaster486
I thought there was such a program/driver/TSR.
Something that acted as software MIDI under DOS, playing (as I remember it) through the OPL3 chip.
World's foremost 486 enjoyer.
Reply 5 of 6, by cyclone3d
It might be possible to do so, but the only things I could find are a few different MIDI players that can use the FM synth.
To make it work for games, you would have to capture the MIDI I/O and forward it to the FM I/O port after running it through a translator.
You probably could get a starting point by looking at the source code for one of the players as far as the translation part goes.
http://dosmid.sourceforge.net/
http://bisqwit.iki.fi/source/fmdrv.html
https://github.com/Wohlstand/libADLMIDI
http://vgmrips.net/forum/viewtopic.php?f=15&t=1935
YMF7x4 Guide
Reply 6 of 6, by yawetaG
There's a Yamaha MIDI driver that allows you to play MIDI via the FM portion of your (Yamaha YMF-based) sound card, but it only works under Windows 95/98 (and probably Win 95/98 DOS window).
