First post, by feipoa
I was thinking it might be beneficial to formulate a list of socket 2/3, 486-class motherboards which work well with the Pentium Overdrive (POD) in L1 write-back mode. And to a lesser extent, perhaps a list in which the POD works well in only write-through mode. And another list of boards which do not work at all with the POD.
From memory, I know the Biostar MB-8433UUD works very well with the POD in write-back mode; the PC Chips M919 v3.4, on the other hand, only works with the POD in L1 write-through mode.
Reply 1 of 35, by jesolo
What's the best way to confirm (or how do you confirm) that your CPU is running in WB mode?
Or, will it simply refuse to boot if you jumper it on the motherboard into WB mode?
Reply 2 of 35, by mrau
if i understand correctly writes will not be accelerated by cache when in write through? so speed measurements should help i suppose
Reply 3 of 35, by alvaro84
Is there a good and sure way to quickly test the cache in WB/WT mode? Or just watch out random instability?
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 4 of 35, by BeginnerGuy
There is a program out there, I'll hunt for it later and see if it exists on the internet. I remember this topic popping up on usenet regularly and there were a few homebrew apps being passed around that could tell you if WB was working.
Browsing the old topics on google groups would be a good start.
Sup. I like computers. Are you a computer?
Reply 5 of 35, by feipoa
Various programs usually will inform you what state the L1 cache is in. The BIOS may or may not mis-report it. Try CHKCPU 16-bit, for example, or cachechk. Perhaps CTCM and CTCM7. I suspect, though, that sometimes the system tries to put the L1 in write-back mode, but the system is just horribly unstable. Try installing Windows 9x, for example, and watch the errors pop up. Also, the Quake benchmark results will offer some insight as to the L1 cache state.
Reply 6 of 35, by Anonymous Coward
Here's a fun fact. Did you know that the Intel Mercury chipset, the one for the P60/P66 also doesn't work properly in WB mode? At least Intel issued some kind of statement recommending that all of their vendors run WT mode because the WB mode was defective. Not sure if it affects some, most or all of the motherboards using the Mercury chipset. So, don't feel too bad that WB doesn't work on your POD, because it didn't even work on a proper Pentium.
Reply 7 of 35, by amadeus777999
Very interesting - never heard of this before.
Reply 8 of 35, by feipoa
Intel probably preferred it that way!
Reply 9 of 35, by feipoa
Nobody else using the POD in their retro systems?
Reply 10 of 35, by kixs
I have it on a shelf... like so many other cool hardware. I'm starting to wonder if I'll ever enjoy any of it for more then a 5 minute test run 🤣
Reply 11 of 35, by amadeus777999
Never saw the appeal of having a Pentium on a 486 board - weaker bus plus one pipeline deactivated. Latter could be hearsay though.
Reply 12 of 35, by alvaro84
I have but not in a pre-built system. I have 4 486 boards though and will check later. In a few weeks, I presume. Sorry 😊
Reply 13 of 35, by bjwil1991
It really depends on the motherboards and BIOS manufacturer. I have a Packard Bell Pack-Mate 28 Plus that'll work with Pentium OverDrives, but require an Interposer, but disables L2 cache all the way.
Reply 14 of 35, by jesolo
I have a Pentium Overdrive (POD) 83 MHz currently in my Asus PVI-486SP3. Works great in both Write Back & Write Through (or Thru) mode.
I also have a Luckystar LS-486E, which I think I initially tested the POD with and it also worked fine in both Write Back & Write Through mode.
Both motherboards utilise the SIS 496/497 chipsets and were one of the "later" 486 motherboards so, I didn't expect any problems.
I initially had an AMD5x86 133 MHz in by Asus PVI-486SP3 but, after I managed to acquire the POD 83 MHz, this CPU appealed to me more to use in my "high end" 486 system (despite actually being a Pentium based CPU).
Based on my own benchmarks, the POD 83 MHz runs more or less on par with a Pentium 75 MHz.
Reply 15 of 35, by feipoa
I recall user Vetz running a POD at 100 MHz in his Asus VL/I-486SV2GX4; don't recall if the POD is in WB or WT mode, though. Obviously, the older the motherboard, the more exotic it would be to have the POD working in WB mode.
Reply 16 of 35, by dirkmirk
I like the Cyrix 5x86-120 much more than the POD-83, faster bus but weaker FPU is a fair trade off IMO.
Reply 17 of 35, by feipoa
The POD only gets interesting to me when its run at 100 MHz.
Reply 18 of 35, by BitWrangler
If you've got a LOT of patience, I'll try and remember this thread if one turns up here. A memory just snuck in of handling one with no fan years back, so if it's still around and turns up, I'll rig something and test on whatever boards are handy.
Really.... The kickass 486 position is held by the AMDs or Cyrixes, and the terrible pentium system crown is taken by the P60 or P75, so it lacks a purpose in life... except maybe the title of "The first CPU intel should have named Celeron." 😁
Reply 19 of 35, by Anonymous Coward
In my opinion, the 60 or 66MHz bus on the pre-Triton Pentiums didn't really matter much, because so many wait states had to be added to make the DRAM and 15ns async cache stable. The memory performance of early Pentiums is not really better than a good 486.
If you have a good board that works with L2 cache enabled and L1 in writeback mode, the POD83 is a pretty good upgrade for a socket3 system. The problem of course was that nobody could really use the POD83 as an upgrade for a pre 1996 board, and you would have had to buy a new one to get the full performance. At that point in time you were much better off investing in socket5/7.
