First post, by Piecho
Hey,
I`ve got great Toshiba laptop with MMx133 but because of my mistakes with retrobright it is damaged now.
1) Stripes on the LCD. Any possibility how to eliminate it?
2) Some keys like Q,A,right arrow normally are not working. But if I press another key and fast one of damaged ones they are working fine. I dont see possibility to disassembly the keyboard, only keys and rubbers may be removed. Any protips how to fix it?
get_thumbnail?sig=pw19H3WbPKQ-79CKzXbJX3Oyzcg&data=vkk75FK4IJe5vnWh39WHtrdjXJE21MAGRWS2nlIVfO95tTyFHNKou-MA79ch_cinyJzO5tQu_6sEVd-ZCulI87-rkfaUMrg4lqPu7aTA-224Fh-lMF72h5_8hV0ivzqtXQQfOjlDhrGpvoV_sq1xfg62naugPwL0JkwUcBECtTAdSXAGP95hlgdMwzAmcTzOxlqvxPtTRLtA140DBW2lxwJSQif1akrXL4NZF32zeD-bV_q9zhSoC5Zgn0Ww2n2kSRu8o_8UU6pxgGzSXqjN6GKOwI0FsF1a_rB86peol_KMz_I7bBXrBIA&ts=1511638711115&w=720&h=720&r=0&_cachekey=d6d239d1779602ecd3d4e6ac65d2c736
get_thumbnail?sig=WtD3NXPg_AodNit2KSH6rO-LUPI&data=vkk7Z60XmmEvTOO9tsy83xN_Ami5G037iBv-ga8tv17dMICFHPrXrFUdk-KXZqONRee5noou_6sEVd-ZlGFyybUPGa9qx0Sn60qyxz_YPQW4Fgud2h6ths8DPsV6mMe99NsfLDyEnKLFk4NNv4BBaACor_akB_CkgONXzUtHm1Bk0S0A4xOeG-feawhTbFe05R-I6c1f37MttitMgnb93jOp1gEm6Q4g5pFYF2G6zZSF4lGj2xS-r9W4el2tlICFu-s4NPOcFjfkahyeL4MVeLEFmXu-y0a5j9d04JPgmK2D2IOo0-BA&ts=1511638711115&w=720&h=720&r=0&_cachekey=402db08823492127645edb0988d84c0e
get_thumbnail?sig=yaXSwo00ytkLCZklapfx750Mi88&data=vkk7opWoifwkH3YUB0nHgxNDihTGG_FDWkZ2NOKTiDOFWLSFHG6xrigUm2D18BZLxJfc6VYu_6sEVd-Zv7HLQxvGOf2zXBB8UoY5fVBuOYO4FsrKKEfVH5mk4n0ltbYkmoAfZCcKhrGpqLFioqRQRgDflZ2gPwKy4Vy9G4yjtoXF1TAzm_63E_eD8nU5U_xkdtxbGAe-zLtAa5QWznnRcNZfnMv5YVjYrYNZF32zeD-bV_q9zhSoC8h-1kWw2sj8yqsYzlcfdMTZxKj3iTg5RqBgwIQiH11a_rB86peol_KMz_I7bBXrBIA&ts=1511646400577&w=720&h=720&r=0&_cachekey=04f1e7b924ff264994dce4350838c796
get_thumbnail?sig=Z3BMlggEaHNNq54177XCYuNNqIQ&data=Az1FVLaudRrgAXGsxUXea28HNxanpE9GhAEajK_HmxBZ_6P9cHPiZU9nnwGwRwfoV8krY4YpWFamNpxbtEUtZBdv0MXLZwkjQgW6r1esAao011PHOZnc8S-LVCBOx2UmxboHpEGKQ9OGy4vG55LSNRL9RSHpXzPSY-hl19fuQ-59jcBsh8z8sBYlUz1DMTQvcTmyEStom-xPsvQFJbAQRqA-G4mHHeOkVuxTEmuVwqXMjdz9T1Ozv152LcujQFFuc2IoYQGnWbgyiNrBddXTkg9cZRfwrI0JCykGPLrZNkyiABY-J_FMZgs&ts=1511646400577&w=720&h=720&r=0&_cachekey=19fab322722220a32d06b8b01ffaad96
Reply 2 of 4, by blurks
You applied retrobright on the laptop without disassembling it first?
Reply 3 of 4, by hyoenmadan
Retrobright contains hydrogen peroxide. It should never be applied to electronic parts, because the peroxide will eat the highly active metals contained in your electronics PCB and flex cables/membrane contained in the keyboard. The damage you did to your device is equivalent of the well known battery leaking meltdowns, and probably the screen and the keyb are damaged by the chemicals beyond repair.
Reply 4 of 4, by SW-SSG
May as well attach keyboard, mouse, and VGA monitor to it and use it as a desktop.
