Reply 20500 of 53280, by yawetaG
probnot wrote:
chose007 wrote:
NTB with integrated printer by Canon[...]
Whaaaat? I've never seen something like that before. Very cool.
It's a type of machine mostly sold in Japan, but apparently some got sold outside of it too.In Japan they get called "Office Assistants" (O.A. for short), and often they run specialized operation systems (e.g. Windows CE) and software. Some are pretty massive, while others are really compact.
Reply 20501 of 53280, by liqmat
dexvx wrote:
Got this BFG GeForce 7800 GS OC. Looks like it can do 2D without any issues. 3D has some texture corruption (and it causes the s […]
Got this BFG GeForce 7800 GS OC. Looks like it can do 2D without any issues. 3D has some texture corruption (and it causes the system to BEEP). Anyone have suggestions on a fix? I might try and bake it.
Beeping, texture corruption when using 3D? What PSU are you using? Had something similar years ago. PSU was not powerful enough. I also try to have my gfx cards on their own wire.
Reply 20502 of 53280, by rikukos
Some recent purchases, past 1-1,5 months or so..
CT3930 (sealed), nice as contains a discrete Yamaha YMF
Real3D Starfighter i740 (sealed)
2 x Voodoo3 3500 (sealed)
STB Voodoo2 (sealed)
Intel Above Board Plus 8 (sealed)
Roland LAPC-I (boxed) and MCB-1 (NOS)
Hercules Terminator 64 (sealed)
Voodoo3 3000 (sealed)
Some newer stuff for my upcoming XP build (all sealed)
Reply 20503 of 53280, by luckybob
ARTEX HAS COMPETITION!
That boxed intel 740 card is really neato
Reply 20504 of 53280, by Vegge
The past weeks purchases :
Pretty happy with this 😀
Reply 20505 of 53280, by Munx
Picked up 2 motherboards today:
MSI K7N420 Pro, Nforce 420 chipset. Wasn't looking for any S462 boards, but I really wanted one with a 1'st gen Nforce chipset. Underneath is an Athlon xp 2000+ Palomino. The previous owner aimed for the very best of early 2000's it seems.
The second board is one of the most Asrock things out there - Asrock 939dual-vsta with AGP, PCI-E support and even an expansion slot for a CPU board
My builds!
The Underdog - The budget K6
Reply 20506 of 53280, by rikukos
Thanks!! Yeah, I've not seen it boxed (only bare cards) so I grabbed it instantly when I saw it. Box is a bit crushed though.
Reply 20507 of 53280, by DaveJustDave
where did you find these??!?!?
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 20508 of 53280, by chose007
JidaiGeki wrote:
Awesome, looks to be in great condition, hope you also got the charger for it. I have two of these, one of which has had a battery leak, so do check inside if you can. The Note Jet was an interesting product back in the day, my father used one for work, he seemed to enjoy it more than other laptops as it was quite handy when he was on the road. Some years later I had to carry around a portable printer and laptop for work, and began to realise how much less hassle it would have been to have an integrated printer.
Also, top score on that Mars card!
I got original charger too. After connect only charging led start blink and thats all, power button do nothing. Baterry looks ok but will be KO like 99%.
Reply 20509 of 53280, by havli
More stuff has found its way to me 😁
Asus X1950 Pro - I had the same one back in 2007 when it was new
Radeon X1550 AGP - should be the same as X1300 Pro, would be nice to include in my tests but no idea if it works yet.
Asus P5PE-VM... you can't have enough Core2 AGP boards, right? 🤣
Asus A7V333 - also can't hurt to have spare KT333 MB for Voodoo machines
Siemens Nixdorf D969...
... with i430HX, my favorite 😁
No onboard L2 cache, just a COAST module
Acer AT board
Also with HX 🤣
And Pentium 133
Reply 20510 of 53280, by badmojo
Jiminy Crickets there's some nice stuff being posted here, nice work new guys!
Reply 20511 of 53280, by blurks
Isa Tseng et4000ax
Would you mind showing us the inside? 😀
Reply 20512 of 53280, by Artex
Holy hell! I would say so!
Reply 20513 of 53280, by Artex
rikukos wrote:
Real3D Starfighter i740 (sealed) https://i.imgur.com/dbVMUsD.jpg […]
Where did you find this?! Been trying to track down a boxed version for a while. NICE score... And welcome to VOGONS!
Reply 20514 of 53280, by rikukos
eBay is your friend 😉 Seriously I guess I was a bit lucky with that i740. Found it when browsing for other things when it just got listed. The seller did not have much other techy stuff (more like dinnerware items and like) so it even was reasonable priced (at least when compared to used, bare cards on eBay).
Reply 20515 of 53280, by Artex
Unreal!
Reply 20516 of 53280, by liqmat
Very interesting. Wife grew up in Vermont and we lived there off and on for awhile. Never heard of them. Guess you could call them Green Mountain Graphics. After looking them up it appears they won a court case against Autodesk who has a major office in New Hampshire. Very cool stuff you found.
Reply 20517 of 53280, by Artex
I'll throw my hat in the ring today.. 😀
MS-6168 Motherboard with Integrated 3DFX Voodoo3 2000 8MB chip. Came with P3-450 and memory.
Reply 20518 of 53280, by liqmat
Never knew they made a motherboard with a Voodoo3 on-board. News to me.
Reply 20519 of 53280, by rikukos
Thanks Artex!! I see you got *some* amazing items when I do search backwards in this thread 😀
Back side of the box..
