Autoexec.bat & Config.sys Help
Reply 20 of 28, by Tempest
Ok I'll run those MEM flags and see what's up./
I don't use smartdrive. I was never quite sure what it did anyway.
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
Reply 21 of 28, by Tempest
Well I think I see the problem, but I'm not sure how to fix it. On my Win 98 box it appears that MSCDEX is entirely in conventional memory rather than upper memory. I think it's because there's not enough free upper memory it needs 27K and I have 56K total, 32K used, 23K free. On my other system (the 486) it has more free total upper memory for some reason (why is this?) so MSCDEX fits nicely into it with room to spare. Any way to fix this?
EDIT: By changing my FILES to 40 and Buffers to 30,0 (as in my 486) and now I have 597K free which I can live with. I just wonder why the big difference in total Upper Memory between the two systems?
Reply 22 of 28, by clueless1
You can run MSD.EXE and go to Utilities->Memory Block Display and Memory Browser. Compare between the two systems to see where the extra memory is being used and what's using it. MSD is a built-in Microsoft utility and it should run from any path.
Reply 24 of 28, by MERCURY127
my current config.sys for 98se on Core i7 machine, with buggy wrong configured 10 KB XBDA:
DOS=HIGH,UMB
STACKSHIGH=0,0
SET PATH=C:\;C:\BOOT;C:\NC;C:\NC\QPV;C:\INFO;C:\MDOS;C:\DOS;C:\ARC;C:\RUS;C:\DOS7;C:\WINDA;C:\WINDA\COMMAND
SET TEMP=C:\TEMP
SET TMP=C:\TEMP
SET TZ=MSK-3
SHELL=C:\COMMAND.COM C:\ /P /E:1024
DEVICE=C:\MLCL\UMBPCI.SYS /U=C800-CBFF // open shadow vrom for further cyr fonts, dont stay TSR
DEVICE=C:\MLCL\UMBPCI.SYS /I=D000-EBFF // open shadow mem for umbs, stay TSR
DEVICE=C:\JACK\XMGR.SYS // XMS & UMB driver
DEVICEHIGH=C:\BOOT\CLARUS.COM 1 30 /S:M /S /Q /W \VGA9\VGA9.FNT // cyr driver
DEVICEHIGH=C:\DOS7\IFSHLP.SYS
DEVICEHIGH=C:\JACK\XHDD.SYS /S5 /H
DEVICEHIGH=C:\JACK\XDVD2.SYS /H
DEVICEHIGH=C:\MDOS\SETVER.EXE
; INSTALL[HIGH] will exec at end only
INSTALLHIGH=C:\160331\SHSUCDX.COM /D:UDVD1 /L:E /R /C /Q
my autoexec is empty. i have 625 KB low mem free, and 635 on my second machine, P3, where used good old 1 KB XBDA.
Reply 25 of 28, by Tempest
Dominus wrote:
I dimly remember that himem.sys and emm386.exe needed more memory for themselves in Windows 9x versions.
That would make sense, I keep forgetting that WIn 98 DOS isn't exactly the same as DOS 6.22
What are some good values for FILES and BUFFERS? I seem to recall that FILES is the number of simultaneous open files allowed and 30-40 is a good range for that, but I'm not sure what BUFFERS does or what a good number is for it. Also do I need STACKS anymore?
Reply 26 of 28, by MERCURY127
if u really want set BUFFERS/FILES/etc manually - use BUFFERSHIGH/FILESHIGH/etcHIGH.
Reply 27 of 28, by dr_st
It doesn't matter; Win98 SE will make them HIGH by default, if high memory is available, unless you use DOS=NOAUTO.
Reply 28 of 28, by dr_st
Once again, I'm posting my current startup files on Win98 SE, and the resulting memory layout.
  • C:\DOSW is where I keep the DOS files of Win98 SE; normally you should use C:\WINDOWS.
  • In Autoexec, I have 3 different audio sections, depending on which card I have installed (currently it's the AWE64).
  • CTCME.EXE is the standard Creative CTCM, which I hacked so it does not complain about running under Win98 SE DOS.
  • FASTKEYS.COM is a small command file which increases keyboard repeat rate to maximum.
CONFIG.SYS
DOS=HIGH,UMB
DEVICEHIGH=C:\DOSW\HIMEM.SYS
DEVICEHIGH=C:\DOSW\EMM386.EXE RAM I=B400-B7FF I=CA00-CBFF AUTO
BUFFERS=20
FILES=60
LASTDRIVE=Z
STACKS=9,256
BREAK=ON
SHELL=C:\COMMAND.COM /E:512 /P
DEVICEHIGH=C:\CDROM\VIDECDD.SYS /D:IDECDROM
AUTOEXEC.BAT
@ECHO OFF
LH C:\DOSW\MSCDEX.EXE /D:IDECDROM /E
LH C:\DOSW\SMARTDRV.EXE /X /B:1024
LH C:\DOSW\DOSKEY.COM /INSERT
LH C:\MOUSE\CTMOUSE.EXE /R33 /3
SET COMSPEC=C:\COMMAND.COM
SET COPYCMD=/-Y
SET DIRCMD=/P/O:GEN/A
SET PATH=C:\BATCH;C:\DOSW;G:\WINDOWS;G:\WINDOWS\COMMAND;C:\NC5;C:\NAV;C:\XTG;C:\CDROM;C:\PV;C:\ARCHIVE;C:\MOUSE;C:\DOSUTIL;C:\SB;C:\OPL3SA
SET PROMPT=$P$G
SET TEMP=C:\TEMP
GOTO AWE64
:SB16
SET SOUND=C:\SB
SET BLASTER=A220 I5 D1 H5 T6
C:\SB\CTCME.EXE
C:\SB\MIXERSET.EXE /P /Q
GOTO END
:AWE64
SET SOUND=C:\SB
SET MIDI=SYNTH:1 MAP:E MODE:0
SET BLASTER=A220 I5 D1 H5 P330 T6 E620
C:\SB\CTCME.EXE
C:\SB\AWEUTIL.COM /S /KEY- /C:50 /R:50
GOTO END
:YAMAHA
SET BLASTER=A220 I5 D1 T4
C:\OPL3SA\SETUPSA.EXE /S
GOTO END
:END
C:\DOSUTIL\FASTKEYS.COM
C:
CD\
CLS
MEM /C /P output
Modules using memory below 1 MB:
Name Total Conventional Upper Memory
SYSTEM 31,856 (31K) 10,912 (11K) 20,944 (20K)
HIMEM 1,168 (1K) 1,168 (1K) 0 (0K)
EMM386 4,320 (4K) 4,320 (4K) 0 (0K)
DBLBUFF 2,976 (3K) 2,976 (3K) 0 (0K)
COMMAND 7,296 (7K) 0 (0K) 7,296 (7K)
VIDECDD 5,024 (5K) 0 (0K) 5,024 (5K)
IFSHLP 2,864 (3K) 0 (0K) 2,864 (3K)
MSCDEX 16,144 (16K) 0 (0K) 16,144 (16K)
SMARTDRV 22,272 (22K) 0 (0K) 22,272 (22K)
DOSKEY 4,688 (5K) 0 (0K) 4,688 (5K)
CTMOUSE 3,312 (3K) 0 (0K) 3,312 (3K)
Free 654,000 (639K) 635,632 (621K) 18,368 (18K)
Memory Summary:
Type of Memory Total Used Free
Conventional 655,360 19,728 635,632
Upper 100,912 82,544 18,368
Reserved 0 0 0
Extended (XMS)* 266,171,856 2,885,072 263,286,784
Total memory 266,928,128 2,987,344 263,940,784
Total under 1 MB 756,272 102,272 654,000
Total Expanded (EMS) 33,947,648 (32M)
Free Expanded (EMS)* 33,521,664 (32M)
* EMM386 is using XMS memory to simulate EMS memory as needed.
Free EMS memory may change as free XMS memory changes.
Largest executable program size 635,616 (621K)
Largest free upper memory block 9,344 (9K)
MS-DOS is resident in the high memory area.
MEM /D /P output
Conventional Memory Detail:
Segment Total Name Type
00000 1,024 (1K) Interrupt Vector
00040 256 (0K) ROM Communication Area
00050 512 (1K) DOS Communication Area
00070 1,424 (1K) IO System Data
CON System Device Driver
AUX System Device Driver
PRN System Device Driver
CLOCK$ System Device Driver
A: - H: System Device Driver
COM1 System Device Driver
LPT1 System Device Driver
LPT2 System Device Driver
LPT3 System Device Driver
CONFIG$ System Device Driver
COM2 System Device Driver
COM3 System Device Driver
COM4 System Device Driver
000C9 5,424 (5K) MSDOS System Data
0021C 10,608 (10K) IO System Data
1,024 (1K) Relocated EBIOS data
1,152 (1K) XMSXXXX0 Installed Device=HIMEM
4,304 (4K) EMMXXXX0 Installed Device=EMM386
2,960 (3K) DblBuff$ Installed Device=DBLBUFF
544 (1K) Sector buffer
512 (1K) BUFFERS=20
004B3 80 (0K) MSDOS System Program
004B8 384 (0K) MEM Environment
004D0 90,464 (88K) MEM Program
01AE6 545,168 (532K) MSDOS -- Free --
Upper Memory Detail:
Segment Region Total Name Type
0B55C 1 5,728 (6K) COMMAND Program
0B6C2 1 1,568 (2K) COMMAND Environment
0B724 1 1,568 (2K) MSDOS -- Free --
0B786 1 1,920 (2K) MSDOS -- Free --
0CA01 2 28,800 (28K) IO System Data
5,008 (5K) IDECDROM Installed Device=VIDECDD
2,848 (3K) IFS$HLP$ Installed Device=IFSHLP
1,200 (1K) Block device tables
3,264 (3K) FILES=60
256 (0K) FCBS=4
10,720 (10K) BUFFERS=20
2,288 (2K) LASTDRIVE=Z
3,072 (3K) STACKS=9,256
0D109 2 16,144 (16K) MSCDEX Program
0D4FA 2 22,272 (22K) SMARTDRV Program
0DA6A 2 4,688 (5K) DOSKEY Program
0DB8F 2 3,312 (3K) CTMOUSE Program
0DC5E 2 5,536 (5K) MSDOS -- Free --
0DDB8 2 9,344 (9K) MSDOS -- Free --
…Show last 33 lines
Memory Summary:
Reserved 0 0 0
Handle EMS Name Size
0 060000
1 008000
Memory accessible using Int 15h 0 (0K)
XMS version 3.00; driver version 3.95
EMS version 4.00
P.S. It would be nice if the forum settings were adjusted so that larger code blocks can be accommodated without forced scrolling, or provide a different way of posting fixed width text (like [pre] or [monospace]).
