First post, by TheAbandonwareGuy
http://www.cpu-world.com/sspec/SZ/SZ956.html
CPU World says only 3 CPU's ever used the socket and there is zero information on it beyond the basic specs. The CPU was obviously made in 1993 which dates it back to the Socket 4 era as far as I know.
Weird CPU. I've had it for a while. It was found inside an AST Advantage 486/SX25 (in a socket it clearly didn't belong in). It appears to be in good shape but I have no way to test it. I'm not a CPU collector and as I understand that's a very rare socket. The only reference I've thus far found to it is in this google archive group: https://groups.google.com/forum/#!topic/comp. … rch/4yfV647ufmw
Reply 1 of 7, by mrau
it probably did belong in that socket, this is compatible with most 486 sockets;
Reply 2 of 7, by TheAbandonwareGuy
It was filling maybe half the socket pins. The outer row of holes wasn't even populated.
Reply 3 of 7, by BeginnerGuy
I've always been under the assumption that PGA169 is socket 1, your basic 486 upgrade socket. 486 CPUs don't populate every pin of socket 3, mine has the outer row completely visible to the eye.
Random image stolen from google:
The attachment s-l1600.jpg is no longer available
So what you have there your basic dx2 overdrive..
Your processor is mentioned here, DX40DP75.
http://philipstorr.id.au/pcbook/book5/overdriv.htm
Sup. I like computers. Are you a computer?
Reply 4 of 7, by jesolo
This should explain the reason for the extra row of pins on 486 sockets: https://en.m.wikipedia.org/wiki/Pentium_OverDrive (refer the section "486 sockets").
As I recall, the 169 pin socket was used as an "upgrade" socket on some 486 motherboards (for the 487SX or 486 "Overdrive" or ODP processors). More on the difference between ODP & ODPR here: http://www.cpu-collection.de/?tn=0&l0=co&l1=I … =i486+OverDrive
For more info on the 487SX: http://www.cpu-collection.de/?l0=co&l1=Intel&l2=FPU#A80487SX
Reply 5 of 7, by TheAbandonwareGuy
AST 486SX won't make any signs of life, not sure where to start?
That's the machine it came out of. What socket was that?
Sadly, I burned the machine a month ago due to corrosion and the fact everything was proprietary, and it made no signs of life. Looking back, I bet it was jumpered to use the overdrive socket that I depopulated. I've just come to the horrifying realization that I might have burned a fixable machine.
Damn.
Reply 6 of 7, by jesolo
TheAbandonwareGuy wrote:
jesolo wrote:
AST 486SX won't make any signs of life, not sure where to start? […]
Damn.
Refer the last post that akula65 made in your other thread - he also provided a link that will provide more information.
However, based on the information provided, it would appear to be your standard upgrade socket that also supports a Pentium Overdrive CPU (which is what the extra row of pins are for).
Reply 7 of 7, by kixs
Like I said on Amibay... this cpu isn't a Pentium overdrive but 486DX-4 75MHz one. Runs on default 25MHz bus and has multi of 3X. Can replace 486SX or 486DX 5V on the motherboards that support overdrive cpus - has to have one additional pin in one corner. There are other 486 overdrive cpus that go into original PGA168 pin socket - they have ODPR in the name. Pentium overdrives go into socket 2 and 3 with 237 pins that standard 486 doesn't use - outer side pins.
Read more here:
https://en.wikipedia.org/wiki/Intel_80486_OverDrive
and about Pentium overdrives for Socket 2/3 (486 to Pentium) and Socket 4/5 (early Pentium motherboards to faster Pentiums):
https://en.wikipedia.org/wiki/Pentium_OverDrive
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
